Pn60e530a3f Y-Main
  • linksys1127
    • Sep 2016
    • 121
    Pn60e530a3f Y-Main
    Does anyone have one of these Y-Main boards lying around and can read the value of resistor R5214 for me. I'm unable to determine through the color bands. It's near the VSCAN circuit. I've replaced the bad caps and chip just want to make sure it's correct. Thank you
  • linksys1127
    • Sep 2016
    • 121
    Re: Pn60e530a3f Y-Main
    Here's the picture from shopjimmy of the board with the resistor marked. Thank you
    • R_J
      • 9625
      Measure it, I think its 0.4 Ω
      Yellow = 4
      Black = 0
      Silver = multiplier .01
      Gold = 5%
      Black is likely TC or something else
      • linksys1127
        • Sep 2016
        • 121
        I would measure it but I’ve misplaced it. I removed it along with several caps to test and can’t find it. I thought it might be .4 ohms as well and the closest I could find near me was .39 ohms. I replaced the IC and caps for the VSCAN circuit as well. The tv powers up fine but I’m getting lots of sparkles. I’ve tried adjusting VS, VE, VA and VSCAN to try to make it look better and can get it to improve but not enough. Thought that I made a mistake on the value of the resistor. All my voltages are spot on. On thing I’ve noticed checking voltages with my meter is if I touch the pin 2 of the photoisolater it puts the tv back to sound only with the long LED flash on the logic board. It may just be turning the isolater off by doing that. I’m not sure. The sparkles are on any input and also doing the logic test so I know I’ve stl got an issue just hoping it had something to do with the resistor but guess not. I’ve also tried another X-Main from shopjimmy but same result. I don’t have a oscilloscope which would help me to isolate the noise. Just a meter with capacitance. I know I’m rambling but I’m kinda hitting a brick wall with my limited knowledge. Thank you for your time.
        • linksys1127
          • Sep 2016
          • 121
          Here's what the video looks like.
          • linksys1127
            • Sep 2016
            • 121
            Here's a picture of the isolater U5003 pointing to the pin that I touched with my meter probe that put the tv into fault.
            • linksys1127
              • Sep 2016
              • 121
              Sorry here's the pic
              • linksys1127
                • Sep 2016
                • 121
                Here's some pics of the boards. I'm just at a loss. All I have is a meter with a capacitance testing function so I've removed and tested all the small blue caps that have been causing problems talked about on this forum. I found 4 of them questionable. Two below 7mf and two reading short. The others test good.
                I thought it might be a bad X-main but replacing it produced the same results. Could be another bad board but not sure which direction to go now. Any advice would be greatly appreciated. Thank you
                • linksys1127
                  • Sep 2016
                  • 121
                  Here's a better shot of the picture I'm getting.
                  • linksys1127
                    • Sep 2016
                    • 121
                    Going into the service menu and logic test and cycling through the different test patterns I can even see the history channel logo in the bottom right. After repair I've always used the Roku box for testing.
                    Not sure what it's called and it's hard to see from the pictures but cycling through the red, blue and green boxes it displays perfectly. I did a software update through USB with no improvement. Does this point towards the logic board?
                    I was under the assumption that the logic test screens were all produced from the logic board and all test patterns would show defects. Thank you
                    • linksys1127
                      • Sep 2016
                      • 121
                      Replaced the logic board with same result. Could this be a bad panel?
                      • linksys1127
                        • Sep 2016
                        • 121
                        Here's a link to the logic board test patterns I'm getting
                        https://vimeo.com/312267815?ref=em-v-share
                        • linksys1127
                          • Sep 2016
                          • 121
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
                          • chth96
                            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                            by chth96
                            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                            Since then, This AC/DC adaptor have been out of order.
                            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                            And Is there any possibility that it will suddenly explode as well as to be out...
                            12-03-2023, 04:40 AM
