Two SONY VCRs eating tapes
  • Tom41
    • Oct 2005
    • 339
    • England
    I have recently obtained a pair of SONY VCRs; different model numbers but I'm 99% sure they have the same insides. I was hoping to use them to transfer some old tapes to digital files, but both of them failed in the exact same way a short time after I started using them. First they were making a slight knocking noise. Then, during a rewind operation the VCR suddenly stopped and ejected the tape still unspooled from the cassette. They now unspool and eject every single cassette that is put in, making a whirring sound that's MUCH louder than it should be.
    Clearly there's something mechanically wrong with them, and it seems odd to me that two different VCRs could have failed in the exact same way. Unfortunately I can't open them up and see what's going on, as they are still under warranty and will be returned to the sellers. Have you guys ever had SONY VCRs fail like this? Is this a common problem? It really sounds to me like either the tensioning has failed or a gear has moved out of place...
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • nomoresonys
    • 12330
    • U.S.
    Re: Two SONY VCRs eating tapes
    https://www.youtube.com/watch?v=u0dOOy_-uMM
    • Tom41
      • Oct 2005
      • 339
      • England
      Unfortunately the vcr shown in this video is quite different to the ones I have, at least what I can see through the tape slot. For example the pinch roller didn't move up and down when loading, and nothing looks out of place...
      • nomoresonys
        • 12330
        • U.S.
        What is the model numbers? you will probably need to take the cover off to fix it.
        • nomoresonys
          • 12330
          • U.S.
          Pretty tough one since you can't open them up, maybe some good electronics spray lubricant: https://www.amazon.com/Max-Professio.../dp/B0030MPJ8S
          • petehall347
            • Jan 2015
            • 4449
            a good proper cleaning helps especially if a bad tape went through it .
            • nomoresonys
              • 12330
              • U.S.
              Been a while since I vcr ed but yeah I remember the head cleaner tapes that you could buy.
              • petehall347
                • Jan 2015
                • 4449
                there is or maybe was proper cleaning tools and products ..think it was chamois leather on a stick for the drum . plus head cleaner spray . i should still have mine .
                • R_J
                  • Jun 2012
                  • 9624
                  DO NOT SPRAY ANYTHING in the vcr it will become unrepairable. eating tapes is usually caused by the takeup reel not taking up the tape, post pictures of the mechanism or at least the model number.
                  If this is the type that has a bottom cover, remove it and post pictures of the bottom also
                  • nomoresonys
                    • 12330
                    • U.S.
                    Problem is, he can't open it up, per post #1.
                    • R_J
                      • Jun 2012
                      • 9624
                      Well if he can't open them due to a waranty issue, spraying them with lubricant will definitely void any warranty. Just return them.
                      • nomoresonys
                        • 12330
                        • U.S.
                        https://www.youtube.com/watch?v=0egTI__8D5E
                        • petehall347
                          • Jan 2015
                          • 4449
                          send them back for sure . test new ones with new tapes if you can still get them .
                          • nomoresonys
                            • 12330
                            • U.S.
                            LOL, right, my bad, forgot how delicate they are, haven't had one apart in years.
                            • R_J
                              • Jun 2012
                              • 9624
                              Some of the best ones I have seen is when people would use the wet type "vcr head cleaners" then put in a regular video tape, you would be supprised at just how much tape that spinning video drum can wrap around itself before it stops
                              • petehall347
                                • Jan 2015
                                • 4449
                                sticky wet drum syndrome
                                • drussell
                                  • Nov 2014
                                  • 144
                                  I really don't understand what the OP is asking. If these units are new (unlikely since Sony hasn't made a VCR for years) then return them. If they're from a thrift store or something then you have a choice. If you think there is enough potential value there vs. what you paid to attempt a repair (which will almost certainly be successful by the sounds of it) then just proceed to void your "warranty" and fix one or both of them. If you take them back to a thrift store, they're just going to give you your money back and then throw them in the dumpster, which seems rather like a shame to me since they're probably perfectly serviceable with a little maintenance. Even a brand new one in box could quite possibly need re-lubrication by now if it has been sitting around stored for a decade or more even though it is NOS.
                                  You cannot do maintenance on or repair a VCR without opening it.
                                  Opening it shouldn't even void the warranty in my opinion, though there could be other opinions on that one.
                                  The only physical breakage I ever remember repairing in a SONY VCR was a small plastic lever in the tape loading mechanism that draws out the tape and wraps it around the head, etc. The little tab where a spring went broke off from wear. I fixed it by drilling a small hole in the lever just inboard of where the tab was and attaching the end of the spring through the hole instead. Worked perfectly well after that. It probably still works if it has been cleaned and lubricated a couple times since then and was never tossed in a dumpster to be rid of that "old" technology.
                                  • Rajnhl
                                    • Oct 2018
                                    • 94
                                    • India
                                    post picture of mechanism.try to clean all rubber parts (belts or pulley) that move play wheels.check tension belt.
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      There may be a pendulum wheel in from the spindles that needs cleaning or the rubber tire needs changing.
                                      • drussell
                                        • Nov 2014
                                        • 144
                                        Indeed, however, the OP states that he wants to somehow magically fix these VCRs without removing any covers and opening them up.
                                        I believe that this would prove to be exceedingly difficult.
                                        • mikey5791
                                          Sony CFS-5000S radio cassette player no FM reception
                                          by mikey5791
                                          Hi forum members,
                                          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                                          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                                          I opened the casing inside and checked for any dry solder, burned component or loose wires...
                                          02-24-2023, 03:48 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                        • Nevillet
                                          Sony CFS-B11 Radio cassette boom box
                                          by Nevillet
                                          I am trying to diagnose this small radio/cassette player where the audio cuts out after a few seconds - then comes back, then repeats.
                                          I've checked the voltage and current coming from the PS board and it seems fine.
                                          I've also powered it from a bench PS and the fault remains.
                                          All of the electrolytics on the audio board are normal with no high ESR's or bulging tops.
                                          Any ideas?
                                          I've attached the service manual for the unit.
                                          Many thanks.
                                          06-29-2022, 06:58 AM
