Two SONY VCRs eating tapes
  • nomoresonys
    • 12330
    • U.S.
    Re: Two SONY VCRs eating tapes
    Is that Geannie available? she could fix it with a blink of the eye, this thread is hilarious.
    • mikey5791
      Sony CFS-5000S radio cassette player no FM reception
      by mikey5791
      Hi forum members,
      In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
      Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
      I opened the casing inside and checked for any dry solder, burned component or loose wires...
      02-24-2023, 03:48 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
    • Nevillet
      Sony CFS-B11 Radio cassette boom box
      by Nevillet
      I am trying to diagnose this small radio/cassette player where the audio cuts out after a few seconds - then comes back, then repeats.
      I've checked the voltage and current coming from the PS board and it seems fine.
      I've also powered it from a bench PS and the fault remains.
      All of the electrolytics on the audio board are normal with no high ESR's or bulging tops.
      Any ideas?
      I've attached the service manual for the unit.
      Many thanks.
      06-29-2022, 06:58 AM
