Strip Lights
  • CraigR
    • Dec 2013
    • 965
    Strip Lights
    I have a Samsung 55" and it has 2 LED strips running down each side. I found the bad LEDS but never replaced this kind standing up so any tips would be helpful or a video is better.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • RooTV
    Replaced LED. Lights on its own but not in the strip
    by RooTV
    I had 1 LED out on a Bauhn ATVS58-0516.
    I had some spares so I took one of an old strip (after making sure it worked) and took the bad one off the strip.
    I then put the replacement one on the strip.
    Now all the original lights light up (same as before) but the new one doesnt.
    I put the backlight tester on each side of the replacement and it lights up no problem.
    What am I doing wrong? This is the first time I have tried this procedure and I thought it went well.
    06-02-2020, 07:52 PM
  • adelage
    220v Led strip flickering
    by adelage
    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
    I know that the best solution would be to get a voltage...
    11-03-2024, 09:49 AM
  • benareeno
    Adjustable dc power supply and tcl led strip
    by benareeno
    I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
    I have an adjustable dc power supply and was trying around 9 volts.
    I have a pic of a single diode...where to put pos and neg terminals to light it up?
    Pic of middle of strip..is this where i light the entire strip?
    And pic of end...or does this light the entire strip?
    Where to put pos and neg for single diode..multiple diodes and the entire...
    07-11-2021, 02:31 PM
