Any body have a service manual or schematics for a LG 50PN4500? I have a service manual but it only list the main board with its schematics. I'm particularly interested in the Y-sus board (EAX64561401)
LG 50PN4500 - fluctuating Vcc/18V supply on Y-sustain board causing fault
Re: LG 50PN4500 service manual with ZYX-SUS board Schematics needed
Watch these two videos.
It is based on real life experience as documented and in our YouTube videos "CWgdAKTZHSo" and "W4nEv07vpmU", to which we regretfully are not allowed to provide links, so you can see them by simply searching for the unique identifiers.
Copy and paste the text in the parentheses " ". -
I watched those videos and bought the repair kit. Which in turn corrected the main issues (Blown fets) on my Y-Sus board.
But now my issue is I have no health light on my control board and I only have sound with no video output. I have all correct voltage outputs (205V,55V,17v,12v,5v,) Except I don't have the 18v at the output pin on my Y-SUS board. My M_on (Monitor on) signal from the main board is there and it is thus activating the M5v (5V) signal on my PS which then is going to my Y-SUS board which is used for the 18V regulation output from the Y-SUS to the control board and the Z-SUS. The control board needs the 18v to generate the 3.3V it uses to function. Thus is is why I believe I don't have my health light or any activity on my control board. Most of the ICs are not labeled with part numbers I can use to look up and see as to which IC and section on the Y-SUS board is supposed to be generating the 18V. I was hoping to find a schematic that listed the parts with pinouts.Last edited by Beau28713; 12-16-2018, 01:04 AM.Comment
LG doesn't publish schematics of their Y and Z sustain boards, sorry.
Post a picture of your boards and we may be able to help.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Okay So I was able to trace out the Y-SUS circuit and I found the 18V regulator (IC205 AS78XXA) that is used for the 18v output at pin 6 of the Y-sus board. The regulator input is only 3.6v and that is why I don't have my 18v and I only have 3.2v at the 18v pin on the Y-SUS board. I will trace out the input to the regulator tomorrow and see why I only have 3.6v input.Comment
I've repaired two of these boards,on both of them one of these white(500V) SMD capacitors failed and shorted,destroying a SMK0460 or the 30F131 and 30F123 in the process.
You can test this 18V regulator off the board,at the datasheet it has a test circuit,but since it's input is low something else may be the culprit.Comment
I have found and replaced all the blown FETS and C417 and 418. Now i'm in the process of repairing the 18v circuit. The regulator is working fine its just not getting the proper input. So I will be troubleshooting that tomorrow.Comment
Still troubleshooting. Having some fluctuating readings at the IC's VCC and regulator inputs. I don't have my 5VF nor do i have my 15VF from the regulators. The regulators seam to work properly. But my PWM Current-Mode Controller (IC 201) VCC input goes up and down from from 6v all the way up to 13v and All my regulator's (IC631 5Vf and IC204 15Vf) input voltages go up and down from 1v to 3v. Gota find out as to why the circuits are doing this.Comment
A mod may help you with the title.
I would start measuring the resistors since that is simple and quick to get out of the way.
Have you followed the PCB trace from the VCC of the 18V regulator? The controllers VCC fluctuate,what if you take them off the board?Comment
Yes sir, This morning I stated reverse engineering and tracing out all the regulator circuits 5v, 15v, and 18v. When i get it all straightened out i will post it here for others to use. I'm going to remove some sketchy components tomorrow and see what effect it will have on the circuit. There is a lot of fluctuation in the voltage for all the reg inputs and IC's Vcc. Something is making go up and down and not staying steady.Comment
Re: LG 50PN4500 - fluctuating Vcc/18V supply on Y-sustain board causing fault
I have edited the thread title, hope it's more appropriate
Sorry I don't have any thoughts right now.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Whats the number on ic201? The ic's usually have a startup cell to produce the initial VCC and then a secondary winding from the transformer supplies the voltage to keep it running, usually about 18-20 volts.
Does the ouput of the ic drive a fet?
I also see there are a couple other voltages that may come from that same transformer and looks like one of them might supply the buffer ic's (caps and diodes [D202 etc.] in corner of board)
One of the lines seems to feed D641 to D644Last edited by R_J; 12-18-2018, 10:13 AM.Comment
One of the lines seems to feed D641 to D644Comment
Tv is up and running.
Initial fault was sound but no picture.
A. 4 faulty fet transistors (Q401,Q402, Q403,Q404)
B. Two blown caps (C417 and C418)
After replacing these I discovered I had no 15v, 5v or 18v rails on my y-sus board and no power to my control board. (Fluctuations in voltages at the regulator inputs 1.8v-3.6v)
A. This was caused by a faulty Pwm fet driver ( ic201).Comment
Cool fix, 2.2 OHMs resistor also replaced?
Careful so they do not touch the back cover metal.Comment
I temp installed the 5 watt resistors so i could test the circuit until my new 1 watt 2.2 ohm batch comes in. The 5 watt ones will be removed before final assembly.Comment
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by fredtredHello!
I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
Problem
My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
(See Attachment 1)
Self Diagnosing
After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by DynaxSCHi,
I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
The situation looks like this:
After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
1. RTC oscillates normally (32.768KHz).
by rustinjustMy main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
Link to part here https://www.ebay.co.uk/itm/222990805243
This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue... - Loading...
