Toshiba 48L1435 Firmware Needed
  • zomi
    • Nov 2011
    • 505
    its flashing red/ green
    Looks like the firmware has corrupted
    Anyone have the flash file for this tv
    thanks
    • 12145
    • U.S.
    Re: Toshiba 48L1435 Firmware Needed
    http://www.dl.toshiba.com/DLY/index....ion=GB&lang=EN
    • zomi
      • Nov 2011
      • 505
      That only works if the tv boots, no ?
        • 12145
        • U.S.
        Can't recall but theres a procedure there in the directions.
          • 12145
          • U.S.
          Hmm, says use remote, I'm not sure, heres the directions tho.
          • vinceroger69
            • Mar 2012
            • 6714
            mainboard 17MB95? what lcd panel is used?
            • zomi
              • Nov 2011
              • 505
              Yes mb95
              screen ves480unvs- m01
              have attached pics too
              • vinceroger69
                • Mar 2012
                • 6714
                maybe pm ducky29 he maybe able too help with the firmware hes helped a few members out with vestel firmware i will keep looking on the sites im registered on too see if i can find any firmware now i have the panel id
                • Skyeface
                  • Oct 2023
                  • 14
                  • Nigeria
                  Please I have a vestel 17mb95 r3 for 42led400s and the picture showing was flip upside down please help me out how can this be corrected.
                    • 12145
                    • U.S.
                    Do you know the history of the tv, the last vestel with a flipped screen we saw not long ago, the problem was a mismatched replacement mainboard, doesn't have to be your problem, just one possibility.
                    • yokoono
                      • Apr 2010
                      • 481
                      Cod panel (VES420xxxxxxxx) ??.
                      • Skyeface
                        • Oct 2023
                        • 14
                        • Nigeria
                        Actually I just bought the board but the panel code is ves400unes-05-b
                        • yokoono
                          • Apr 2010
                          • 481
                          You have the panel profile below. With him you make the right image. I hope you know the installation procedure. It lasts 1 minute.
                          • Skyeface
                            • Oct 2023
                            • 14
                            • Nigeria
                            No Please can you guide me on how to install that
                            • Skyeface
                              • Oct 2023
                              • 14
                              • Nigeria
                              • yokoono
                                • Apr 2010
                                • 481
                                1. Format a stick with FT32
                                2. Create a folder on the stick called pq
                                3. Unzip the profile and put the resulting file in the folder
                                4. Turn on the TV and insert the USB stick
                                5. Type MENU and then 4725
                                6. Go down to USB Operations and type OK. Wait 5-10 seconds
                                7. Exit the menu and turn off the TV. Wait until the stby LED on the TV stops flashing
                                8. Unplug the TV and wait until the stby LED goes out.
                                9. You turn on the TV and everything should be ok.
                                • Skyeface
                                  • Oct 2023
                                  • 14
                                  • Nigeria
                                  Ok Thanks, I have done that so let me turn the TV on back
                                  • Skyeface
                                    • Oct 2023
                                    • 14
                                    • Nigeria
                                    Still the same the image is still flipped upside down
                                    • yokoono
                                      • Apr 2010
                                      • 481
                                      1. Use a stick with the smallest capacity (max. 16Gb)
                                      2. You use another stick
                                      3. Type MENU 4725 and see if the panel has changed to VES400UNES-05-B
                                      4. If something hasn't changed, you're not doing it right.
                                      • Skyeface
                                        • Oct 2023
                                        • 14
                                        • Nigeria
                                        But I used 32gb flash
