A few months ago I traded an LG 50UH5530 for services from a friend of mine. It had the single backlight logo flash then no picture at start-up. The diagnostic led to the replacement of one LED strip, sourced from fleabay and out of a new freight damaged TV.
Fast forward to this weekend....when my friend tells me the backlights went out again, same backlight logo flash then no picture. Based on his description and to save him time I went ahead and pre-ordered all new backlight strips from ShopJimmy.
So last night I went and got the TV, opened it up, pulled the panel and checked each backlight strip with the LED tester. I was puzzled when all the strips lit up and tested at about the same parameters.
It took me a bit to figure it out, but I found the backlight strip I installed a few months ago had failed.
When I change out LED strips I've been leaving the boards on back hooked up so once the panel is out I can still turn the TV on and see the backlights driven at full power. This is how I found the bad strip. The 30mA my LED tester puts out wasn't loading the LED's enough to make the weak link fail, it took the full power of the LED output on the PSU to make it show up. You just have to remember to pull the FFC's out of the T-Con so when the set is powered on there is no chance of shorting that signal to ground....and it goes BOOM.
These LED testers are great and will find bad LED's 99% of the time, but sometimes they don't have enough power to make some LED failures show up. It's just something to keep in mind when using one of these testers....they are a good answer but sometimes not a perfect one.
Used LED strips from Fleabay may also not be a perfect answer. The bottom line from now on is when backlights go out the best answer that leads to the least amount of future trouble is to buy them all new, install them new and keep the backlights turned down after.
Since the LED strip I installed 3 months ago is what failed I didn't charge him for the new strips or labor. I mean what kind of prick would I be to charge him for my mistake? I wouldn't do that to a friend...or anyone. If one can't be trusted with a little then they can't be trusted with a lot.
Any job worth doing is worth doing right. I believe new LED strips are the way to go when originals fail.
