Lg 60pz250n-zb
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Lg 60pz250n-zb
    I meant lead solder.(FU@#$&% AUTOCORRECT)60/40 is good. You may have some shorted IBGT's on the ysus and the zsus. Check them also.
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • adelfr2009
      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
      by adelfr2009
      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
      09-28-2025, 10:21 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • aaronkatrini
      Help me find the short circuit on this WORKING Nvidia GTX1650
      by aaronkatrini
      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
      04-18-2024, 03:15 PM
