Samsung UE40J5200 turns on and of in a loop
  • trosdepep
    • Jul 2012
    • 70
    • Spain
    Hello Friends this is my problema with a Samsung Ue40J5200 led tv.
    When I connect the plug, the TV turns on, the smartv logo appears and then the selection of the inputs but the remote control does not respond and after 10 or 20 seconds it turns off and repeats itself in a loop.
    The remote control responds for a second after the smartv logo then dies.
    I have tried to press the secuence mute/2/5/8/exit keys while the smartv logo appears and sometimes the screen remains black but totally blocked, so I unplug it and when reconnecting it starts the loop again.
    What is your opinion?
    Any help is appreciated.
  • trosdepep
    • Jul 2012
    • 70
    • Spain
    Re: Samsung UE40J5200 turns on and of in a loop
    These voltages are present on cnm803:
    -----------------------------cnm803 (plugged)---------cnm803 (unplugged)
    Pin 1,3,5,7 (13V)-------------------13.1V---------------------12.8V
    Pin 2 (UD)---------------------------4.4V-----------------------4.3V
    Pin 4 (PWM_BLU)-------------------0.5V-----------------------3.5V
    Pin 6 (PW ON/OFF)-----------------6.1V-----------------------3.9V
    Pin 8,9,10 (GND)
    Backlight --------------------------203V----------------------175V
    Pin 4 should show 8V on stand by and 13V on power on
    I dont know if it is supply problem or main problem….
    • nomoresonys
      • 12332
      • U.S.
      Do you have backlights? if not try unplug cable from powerboard to mainboard turn on tv, see if backlights come on.
      • trosdepep
        • Jul 2012
        • 70
        • Spain
        Yes, first "Samsung Smartv" logo appears and then dtv channel selection, but remote and power buton no responds, in 20 or 30 seconds restarts on a loop
        • nomoresonys
          • 12332
          • U.S.
          Seems like a mainboard problem.
          • nomoresonys
            • 12332
            • U.S.
            Your firmware may have gotten messed up, with tv not working right you might not be able to do an update/reapply tho?
            • trosdepep
              • Jul 2012
              • 70
              • Spain
              I think too…
              I dont know if it is possible solve….
              • nomoresonys
                • 12332
                • U.S.
                Maybe try to find a reasonably priced mainboard.
                • trosdepep
                  • Jul 2012
                  • 70
                  • Spain
                  Many thanks for your help, Im watching for it.
                  Any other sugerence is apreciate
                  • nomoresonys
                    • 12332
                    • U.S.
                    Could try checking some voltage regulators, here's an example. A decent video how to is worth a thousand words. https://www.youtube.com/watch?v=ocqn...0Fk_YPqYREoqD-
                    • yohnsee
                      Semi-noob
                      • Dec 2017
                      • 198
                      • Hungary
                      +1. Something is very wrong with these samsungs. I talked to a few of my "service-friends", but none were able to solve this kind of issue on component level. They also change the mainboard, it is faster and less stressing
                      Edit: Have you tried one of these? https://forum.samygo.tv/viewtopic.php?f=88&t=9425
                      Here you will need T-HKMFDEUC (UEXXJXXXX)
                      Worth a try.
                      Cheers, Janos
                      • nomoresonys
                        • 12332
                        • U.S.
                        Agree, for sure, I'd rather pay a hundred dollars for a board than spend 20 hours trying to figure it out.
                        • trosdepep
                          • Jul 2012
                          • 70
                          • Spain
                          +1.
                          Worth a try.
                          I download a firmware but how do I install it on tv, by usb? TV does not respond to anything.
                          Can it be updated in another way? flashing rom…
                          I have spi flash programmer (I ve repaired some tvs flashing eeprom)
                          I have found a 48 inch main board (mine is 40 inch) it has same reference (BN41-02482A) this card is right for me?
                          • nomoresonys
                            • 12332
                            • U.S.
                            https://www.samsung.com/uk/support/t...sung-smart-tv/
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4543
                              • Italy - Milan
                              With the spi flash programmer you do nothing, Samsung usually stores main software on NAND flash or emmc, if your is the first try searching the web for "[Model] programmed NAND" then you can buy and solder it.
                              • trosdepep
                                • Jul 2012
                                • 70
                                • Spain
                                I´ve buyed new main board (50€). Now tv works fine. It comes with 1111 software but there is a new software update 1121.
                                Is it better to update the software or leave it as is?
                                • nomoresonys
                                  • 12332
                                  • U.S.
                                  Good question, sometimes an update will take away some of the smart features of a tv, WHY? I don't know? I would try and see if anyone has lost features with the new update. Maybe turn auto update off if tv has that setting. CAUTION, very often you can not downgrade/go back to previous firmware.
                                  • trosdepep
                                    • Jul 2012
                                    • 70
                                    • Spain
                                    Thank you for all, now I have last update installed.
                                    All is right but remote not works with new software, it was an old Samsung remote. I need an original remote now.
                                    • Takeatry
                                      Yet another Samsung QLED Boot Loop
                                      by Takeatry
                                      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                      10-04-2024, 02:57 PM
                                    • giova96
                                      samsung qe55q60rat logo loop
                                      by giova96
                                      Good morning
                                      I have this Samsung which has the typical display problem, basically I see the initial Samsung logo for a few moments and then restarts
                                      I have the audio from the antenna present, by disconnecting a flat panel from the display the TV remains on with the audio of the program present, but everything on the screen is black (backlighting present)
                                      I know that there are steps to save it by performing operations on the panel card
                                      Does anyone have a more detailed guide? given that this is already the 4th TV that this has happened to me and it seems like a fairly well-known...
                                      03-06-2024, 03:30 AM
                                      09-07-2024, 05:50 AM
                                    • eigma
                                      Samsung UN40H5003 boot loop every ~8 seconds
                                      by eigma
                                      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                      Main board: BN94-07592P / BN97-08922R...
                                      11-20-2024, 10:31 PM
                                      09-06-2024, 11:40 PM
