samsung qe55q60rat logo loop
  • giova96
    • May 2023
    • 38
    • italia
    Good morning
    I have this Samsung which has the typical display problem, basically I see the initial Samsung logo for a few moments and then restarts
    I have the audio from the antenna present, by disconnecting a flat panel from the display the TV remains on with the audio of the program present, but everything on the screen is black (backlighting present)
    I know that there are steps to save it by performing operations on the panel card
    Does anyone have a more detailed guide? given that this is already the 4th TV that this has happened to me and it seems like a fairly well-known problem​
    panel: CY-RR055FGAV1H
    card : bn94-14007b
  • nomoresonys
    • 12323
    • U.S.
    Keep in mind if it is a panel short it can be in about any of the involved line/s: https://www.youtube.com/watch?v=pfrRhw7-ZII
    • giova96
      • May 2023
      • 38
      • italia
      I unplugged the dish, the TV stays on but in no case can I see the image
      • nomoresonys
        • 12323
        • U.S.
        Not positive but it seems these models can have have problems with components on panel driver board, maybe a defective diode pack, resistors or the like, can do some testing. Maybe check youtube, could try a search here possibly for bad diode pack or such, that's if this model has those packs, some don't.
        • giova96
          • May 2023
          • 38
          • italia
          I'll do some tests
          I noticed that the 8 clock pins are not present​
          • viking6791
            • Aug 2018
            • 45
            • My Desk
            The panel has problems, in some cases I managed to make it work (the devices have been working for two months without problems), but it is not a long-term solution. Read the attached link where the given solution is for bootloo​p https://www.badcaps.net/forum/troubl...ines-on-screen
            Post also mainboard photos and and panel board with COF.
            • Takeatry
              Yet another Samsung QLED Boot Loop
              by Takeatry
              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
              10-04-2024, 02:57 PM
              09-07-2024, 05:50 AM
            • eigma
              Samsung UN40H5003 boot loop every ~8 seconds
              by eigma
              Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
              Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
              SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
              Main board: BN94-07592P / BN97-08922R...
              11-20-2024, 10:31 PM
              09-06-2024, 11:40 PM
