Re: Sony KDL-55EX620, no stand-by volts from one bad resistor?
You would use chassis ground or pin 1 of cn6002, You can find out which resistor it is by puting a probe on CN6002 pin 9 and check to each of the 4 resistors of RB9031. the point that is 0Ω is pin8, now check the other side (pin7) of the resistor to ground, that will check the input point (AE5) of the ic9000
At what ground point should I measure, and on what side of the resistor?Last edited by DXseekerMO; 12-06-2018, 07:23 PM.Leave a comment:
When checking resistors use ohm setting, not diode test, in this case the resistors are each 100Ω. If you check from ground to the one that is connected to the ac_off_det line it is likely close to 0Ω to ground
If that line is LOW the ic believes there is a problem with the power supply so it won't allow it to be turned onLast edited by R_J; 12-06-2018, 07:12 PM.Leave a comment:
So I guess that confirms a short in the X-REALITY processor, IC9000?Leave a comment:
That makes sense. So there's really nothing to short out on that circuit on the main board but the X-REALITY processor?
EDIT: Just saw your addition to last post, will check schematicLast edited by DXseekerMO; 12-06-2018, 06:27 PM.Leave a comment:
Voltage comes up to 4.44V with CN6101 detached from PSU
4.44V on the 444th post. You have to be kidding me!Last edited by DXseekerMO; 12-06-2018, 06:15 PM.Leave a comment:
If you disconnect CN6101 from the main board, does the voltage come up to 3.3 volts? Somethings killing itLeave a comment:
with the red probe on C and black on E it tests open
Reverse the probes and the reading is 1.297
Diode check mode used. Confirmed I tested the right transistorLeave a comment:
Check Q6402, It must be shorted e-cLeave a comment:
Yes it is zero voltsLeave a comment:
Yes I was, but its not so Re check the voltage on PH6302 pin 3, it should be 0 voltsLeave a comment:
Unplug CN6102 and check it again.Leave a comment:
Voltage at pin 7 of CN6101 is .47VLeave a comment:
Ok so that crispy Q6302 transistor is likely ok, it has 18 volts on the collector which means the power supply is in standby mode. (not on)
So just to refresh, what is the voltage on CN6101 pin 7 (AC_OFF_DET)?Last edited by R_J; 12-06-2018, 05:34 PM.Leave a comment:
Resistor R6307, collector volts is 18.67 volts measured against hot ground
Thank you for issuing correction, I meant Q6402. I asked if we were transitioning away from Q6301 and more towards Q6402 because budm gave a +1 on the possibility of it being shortedLast edited by DXseekerMO; 12-06-2018, 05:28 PM.Leave a comment:
Q6401??????????????
Q6301 is the switch controlled by the power on opto, you could diode check it or check the voltage on the base and the collector
Its collector connects to pin 28 of IC6501Last edited by R_J; 12-06-2018, 05:25 PM.Leave a comment:
You can check the base voltage on pin 3 of opto PH6301, I'm more interested in the collector voltage and the condition of this crispy transistor.Leave a comment:
So are we transitioning away from Q6301 and more towards Q6401?
When testing Q6401 is that in diode mode and which probes on the meter go to which pin?Last edited by DXseekerMO; 12-06-2018, 05:14 PM.Leave a comment:
by brithepi2kHi,
I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
cheers...5 Photos -
by corrizeHello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks... -
by x_orange90_xI just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
The power supply is 715G8413-P01-001-0H2S... -
by rabbitukI have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...-
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
- Loading...
