Emerson LF501EM5F won't turn on/stays on standby
  • cotstem
    • Nov 2018
    • 6
    Hi all!
    I'm new to the forum and I have a TV that is giving me trouble. As the title suggests, I have an Emerson LF501EM5F that I can't seem to turn on but the standby LED is lit when plugged in. I have searched Google and other posts on this forum but to no avail.
    I did some basic troubleshooting, however I admit I have limited knowledge: I examined both the power board and main board for any abnormalities such as blown caps or burn marks but both boards are in really good shape.
    I don't even know if this is useful but I used the diode setting on my multimeter to try and make sure that the power button was sending a signal to the main board just to try and see if I could eliminate the possibility that it could be the button board or the IR board. If I did it correctly it tested fine. Unfortunately at the time of this writing I do not have a remote for the TV.
    I checked the main fuse on the power board with my diode meter and if I did it correctly it is making a proper circuit.
    I know that there are other posts on this forum about this product but none of them have the exact problem I am having. I did however try to follow along with some of the troubleshooting but I got a little lost because of the technicality of some of it.
    I've seen you guys help out a lot of people on this forum, and I greatly appreciate your help!
  • neilc6
    • Nov 2015
    • 1550
    Re: Emerson LF501EM5F won't turn on/stays on standby
    Searching the model number finds lots of repair kits and repair services in ebay.
    I would suspect the eeprom.. Blsst it with a can of upside down duster to freeze it and then plug it in. If it turns on, its the eeprom. If it doesn't, it still may be the eeprom.
    https://ebay.us/e1PABn
    • cotstem
      • Nov 2018
      • 6
      I tried it but I only had enough duster for one run. I'll get some more tomorrow and try again. Thanks.
      • cotstem
        • Nov 2018
        • 6
        I tried your test and nothing happened, what makes you think it is the EEPROM?
        • CapLeaker
          Leaking Member
          • 8134
          Could be the EEPROM indeed. These are 15$ at SJ, or a new main board. You could freeze the EEPROM with a can of air upside down, then try to turn on the TV. If it turns on, you know what the problem is. I have a 70% success rate using this trick.
          • neilc6
            • Nov 2015
            • 1550
            If you have standby voltage and your other voltages are good, then the main board is suspect since it needs to send a pwr_on signal from the main processor. If you can find preprogrammed eeproms for your model, then the eeprom is suspect and should be cheaper than replacing a main board.
            I've successfully replaced eeproms on 3 tvs that use that same processor and had standby led and didn't turn on (Element, Emerson, & Haier). Only one turned on with freezing.
            • cotstem
              • Nov 2018
              • 6
              Thank you guys, I will try that.
              • cotstem
                • Nov 2018
                • 6
                I ended up using a repair service on eBay. I just didn’t trust my own soldering skills. With shipping, the cost was about $65 and it took less than a week.
                • howardc64
                  by howardc64
                  Yesterday, 05:17 PM
                • brzostos
                  HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                  by brzostos
                  Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                  After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                  Original HP 150W power supply, the diode in the power socket lights...
                  10-01-2024, 01:34 AM
                • maxim2511
                  LG 55EC930V OLED - swich on swich of no screen
                  by maxim2511
                  My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                  Then I get an idea to take it apart and clean boards from dust.
                  In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                  Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                  05-14-2021, 02:21 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
