Philips 55pfl6007k/12 no picture, bricked software ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Got this Philips POS TV which doesn't start. Actually it DOES start but has no picture and no backlight. No it's not a backlight issue because I tested the PSU separately and it works. It's most likely a software issue....and this being a Philips with their fancy ComPair junk box, it's unlikely to be fixable.
    So: you plug the TV in, there's no LED coming on at the front, no sound, no backlight, no picture, however the remote makes the LED flash, so there is something going on, but no "brain" activity - just "low-level" reactions I grabbed the service manual here and I proceeded to the error code list and how to get the board to display them, since there's no picture and no ComPair available (): you solder a piece of wire from the "SDM" pad to GND and that activates the error codes via the LED at the front which now actually provides some usable information: code 53. I interpreted this by following the procedure described in the manual which is 5 slow blinks and then 3 rapid blinks, which is "MIPS doesn't boot (SW cause)". Unfortunately this could be a bad NAND as well (which I believe is the cause, since it's a fairly common occurrence on TVs nowadays: software doesn't just "brick" like that - the memory itself fails more often, like a memory stick, since I think it's the same thing fundamentally).
    Couldn't really find how I'd go around reloading its software (provided of course everything's still OK physically) and even after the fact, I couldn't find a firmware for it....any ideas or is it going in the trash along with the other Philipsssses ? Cheers and thanks.
    Wattevah...
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: Philips 55pfl6007k/12 no picture, bricked software ?
    Ill send you the firmware for this tv so you can try
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Ok, cool thanks. Not sure how I'd start the update though, since I can't see anything.....will have to read deeper in the manual to find out
      Wattevah...
      • danieliod
        • Jan 2020
        • Israel
        Hello, i'm experiencing the same issue, is there a solution and a walkthrough?
        • kiko1
          • Apr 2016
          • 48
          • croatia
          anyone???
          another one here....
          eventually mine powers up..but shady(grainy) picture...and no REMOTE response
          maybe I will try MCU reball
          • prsnr
            • Mar 2021
            • Bulgaria
            Did you send him the firmware?
            Did he fix it?
            I'm wondering if I can downgrade my Philips 43PUS6554 from TPM196E_091.003.255.001 to TPM196E_091.003.166.001.
            I have the both upgrade_loader files.
            • Diah
              • Feb 2013
              • 6357
              Did he fix it?
              yes you can downgrade
              here all firmware for Philips for upgrade & downgrade... thanks to Alex..
              yours 2019 / 6554 download only with note ( Upgrade_Loader ) as pkg
              use google to translate from German language if you are not sure.
              • prsnr
                • Mar 2021
                • Bulgaria
                Hey, I downgraded successfully and fixed the problem that I had
                Alex is great! I owe him so much!
                The problem was that I could not cast YouTube videos from my laptop to the TV.
                This happened after update TPM196E_091.003.210.001.
                The sad thing is that Philips Support told me that downgrade is not possible because the TV might not accept the older software version.
                They also said that the problem is not on the TV's side...
                Their "specialists" are so incompetent IMHO.
                P.S. Here is a video after I fixed the problem
                https://www.youtube.com/watch?v=qbnUJyfY7_Q
                • maximiliams
                  • Dec 2020
                  • licata
                  Ragazzi chi mi puo aiutare ho questo modello philips 55pfl8008s/12 con firmware corrotto , la tv non si accende proprio, sapreste indicarmi un link dove poter scaricare la versione che ripristina la tv brikkata?
                  vi ringrazio anticipatamente a chi mi rispondera ,grazie Max ^_^
                  ________________________________________________
                  Leute, die mir helfen können Ich habe dieses Modell philips 55pfl8008s / 12 mit beschädigter Firmware, der Fernseher lässt sich überhaupt nicht einschalten, könnten Sie mir einen Link nennen, wo Sie die Version herunterladen können, die den Brikkata-Fernseher wiederherstellt?
                  danke im voraus an die, die mir antworten werden, danke Max ^ _ ^
                  • Rauni
                    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                    by Rauni
                    Hello, this is my first post on this forum, and my first attempted to repair a TV.
                    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                    Read also that we should test what happens if we...
                    10-01-2023, 12:06 AM
                  • Schwoin
                    Philips 243v5lhsb00 Monitor Picture too bright
                    by Schwoin
                    Hey everyone,
                    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                    you can see them on the top half of the photo.
                    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                    03-21-2023, 12:40 PM
                  • madyoyo
                    Philips 37pfl560: Yellow picture
                    by madyoyo
                    HI.
                    I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                    Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                    05-30-2025, 10:16 AM
                  • kotel studios
                    Philips SAA7134 TV tuner card - requiring drivers and software
                    by kotel studios
                    Sorry if I posted this in the wrong forum.
                    As mentioned in the title I'm looking for Philips SAA7134 TV tuner card driver and software. Sadly I couldn't find anything online. Maybe someone here has them?
                    02-09-2025, 07:25 AM
                  • charlesdutcher
                    No picture issue in Philips Chassis FTL2.1
                    by charlesdutcher
                    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                    Is there someone having any symptom like this? How to fix it?
                    Thanks in advance!​
                    08-06-2024, 09:55 PM
