What type of fuse is this?
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Picked up a Samsung PN51F8500 that the owner said wouldn't turn on.
    First thing I noticed is that the fuse right after the power is blown.
    It is a T12AH 250v. I thought that it was held on the board with a holder that is soldered in, so I unsoldered one end to replace the fuse but it's sll one piece.
    What is it called so I can try to buy one?
    • 31015
    Re: What type of fuse is this?
    ceramic 12A delay/slow-blow 32mm with pigtails.
    • neilc6
      • Nov 2015
      • 1550
      12A 250V ceramic. Just has wires soldered to the ends instead of using a fuse holder. Blown fuses typically means shorted FETs so check them before replacing the fuse.
      • jetadm123
        • 2169
        Something like this:
        https://www.mouser.com/ProductDetail...jwtDp%2fjPY%3d
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          Thanks.
          I already ordered the fuses. A 5 pack for $10. They were listed as axial fuses.
          I probably won’t bother with anything else if it blows a fuse again.
          I don’t remember how to test the fets and not sure I want to spend more on it.
          Edit: I see a repair kit with two fets and the fuse is on eBay for less than I paid for the 5 fuses.
          How do I check which are shorted? There are more than 2 on the psu.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            dont waste money on special fuses . get some 12 amp fuse wire but watch for fire it is sure to blow again . or solder to a regular time delay fuse
            • neilc6
              • Nov 2015
              • 1550
              They will typically short gate to drain. Just probe with a multimeter. Usually a TO220 package mounted on a heatsink.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                That’s what I thought. The two listed in the repair pack on eBay are testing fine.
                Since I already ordered the fuses, I’ll try one. If it blows, I’ve lost $2.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  check diodes and bridge rectifier for shorts
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    Thanks. Since the fuses have already be ordered, I will try that first. Not sure which the bridge rectifies are. Lol.
                    I can check the diodes.
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      square block near power inlet on pcb . 4 legs . unless it uses 4 diodes instead .
                      • neilc6
                        • Nov 2015
                        • 1550
                        you can also measure the resistance from the fuse to hot side ground to confirm the short. Rectifier pins should be marked ac + - ac . Check the resitance between + and -
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          With my limited skill, I can only determine a blown fuse which is missing right above the power inlet.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            check all diodes and the other fuse .
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Everything else checks out.
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                replace fuse and check ohms across power lead
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  What should I be looking for?
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    Replaced the fuse, the minute I plugged the power in, the fuse blew.
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      • United Kingdom
                                      just as predicted then .
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        Yup, but only cost $2. Should I try one with the other boards disconnected from the psu? To make sure they aren’t causing it to blow?
                                        I hate to spend too much. The tv cost me $20. Probably couldn’t get more that $125 for it.
                                          Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 09:10 PM
                                          Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        • electronx
                                          Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                                          by electronx
                                          I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                                          1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                                          According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                                          If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                                          06-26-2025, 03:27 AM
