LG 22LE3300 completely dead
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    I got the 22LE3300 from LG tomorrow and it's completely dead, the problem is not on the external PSU as i test it and tried with bench PSU too.
    Nothing seems burned on the board.
    Please advise
    Thank you in advance!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8342
    Re: LG 22LE3300 completely dead
    So, that TV is dead as a door nail. Much more testing has to be done in order to figure out what is going on here. You have to find out if:
    -STBY voltage is present on the PSU and getting to the main board.
    -PSon and BLon coming from the main board is present on the PSU after you turn on the TV
    -or maybe the TV is on and the backlights are off.
    This being said, if your PSU has been tested by forcing it on, I'd say you have a main board problem.
    If you have not any PSon or BLon sending from the main board to the PSU, the main IC on the main board is bad.
    • R_J
      • Jun 2012
      • 9607
      This tv uses a seperate 24volt power supply (brick), (page 24) Looks like power comes in as VGH (+25v), check R627 (0Ω) Check VDD_LCM (+16v)
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        This is a Main Bd. problem then? If it is possible, a re-cap may start up the TV.
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
