Panasonic TC-L32B6 bad picture
  • henryvrensburg
    • Oct 2018
    • 104
    Hey guys
    I have a Panasonic TC-L32B6. Everything works on the TV, it just has bad picture. It looks as if there is a lot of vertical lines on the screen, although you can not see them. Text looks "striped" and it just has overall bad picture.
    Can you please help
    Thank you
    Henry
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TC-L32B6 bad picture
    Clean the FFCs from T-CON Bd. to Panel with ISA.
    • henryvrensburg
      • Oct 2018
      • 104
      Can you please explain FFC's and ISA
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        FFC- Flat Flexible Cable and ISA-Iso-Propyl Alcohol...
        • henryvrensburg
          • Oct 2018
          • 104
          Thank you Andrew F.Ali, I will try this, and also thank you for clarifying the terms.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Oh...my mistake. It is not ISA but rather it is IPA for Iso-Propyl Alcohol
            • neilc6
              • Nov 2015
              • 1550
              If cleaning doesn't work, replace the tcon.
              • henryvrensburg
                • Oct 2018
                • 104
                Hi guys
                I replaced the T-CON already. I didn't try the cleaning advise yet. Was out of town for the weekend. Will try that tomorrow night, and hopefully that works.
                Thank you for your advise and time
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  When cleaning soak a piece of lint free fabric with the IPA and wipe the Golden fingers on each end of the FFCs away from the end so as not to disrupt/damage the fingers. Be careful!!
                  • henryvrensburg
                    • Oct 2018
                    • 104
                    Hi Andrew, I tried cleaning the FFC's as per ypur instructions, but with no luck. The TV works perfect it's just as if its 480 or even worse. Even the Menu are striped. I also replaced the T-Con. Can it be the Mainboard, I'm just thinking maybe it doesn't switch to 1080 or 720. Just thinking out loud.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      If it is the Mobo you would get missing VERTICAL lines, it most likely is a bad Panel. Sorry.
                      • henryvrensburg
                        • Oct 2018
                        • 104
                        Thank you Andrew, I was afraid that is the issue. Thanks for your help
                        • henryvrensburg
                          • Oct 2018
                          • 104
                          Hi Andrew, speaking of lost vertical lines, isn't that what I'm seeing.
                          Please look at pictures again, or isn't that what you mean by Lost vertical Lines
                            • 12330
                            • U.S.
                            Vertical lines run from top to bottom ||, horizontal lines run from side to side _ _. A lot of times horizontal lines mean panel problem.
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              That looks to me like lost horizontal lines from the photos
                              • FZG
                                Panasonic AG-1000B VHS player with bad picture quality
                                by FZG
                                Hello!
                                I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                Also, what mechanism is this?
                                Any feedback is appreciated!...
                                05-06-2024, 07:16 AM
                              • Bazfletch3
                                Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                by Bazfletch3
                                Hi all
                                While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                From there I envisaged that the backlighting wasn't working, however...
                                01-08-2024, 10:18 PM
                              • Tr0ll
                                by Tr0ll
                                Original T-con:
                                First replacement T-con:
                                10-07-2023, 07:48 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • mar1in
                                Panasonic TH-55AS670A no picture no sound
                                by mar1in
                                I've got this Panasonic TV here with the following symptoms:
                                * Standby Light is solid RED
                                * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                                * After a couple of seconds, LED is solid GREEN and without picture or sound.
                                I've tried a couple of things before tearing it apart:
                                * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                                * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                                09-10-2023, 11:10 PM
