Sharp lc-52sb55u powers on then off 3 secs later
  • Shibbybag
    • Nov 2018
    • 13
    Ok so I have this tv it does the green power blinks over and over but if I hold down the power button something clicks and the light turns red. Then I press again and tv powers on screen lights up as in shows the whole snowy screen and then back off real quick and flashes the green power led again. I looked but don't see any blown caps. What can I check
    Re: Sharp lc-52sb55u powers on then off 3 secs later
    For us to help we will need good clear pictures of the whole backside of the TV showing all the boards, and the straight shot pictures of the whole top and bottom side of the power supply board so we can read the printed texts on the board.
    It is hard to do long distant troubleshooting without seeing what we are dealing with.
    What is the history of the TV? Any works were done to the TV before?
    The more details we get the better chance of finding the cause of the problem.
      • 12268
      • U.S.
      Last one I had with a snowy screen turned out to be a faulty mainboard.
      • Shibbybag
        • Nov 2018
        • 13
        Ok I will get all the pictures needed and upload them. No other work was done to the tv that I'm aware of.
        • Shibbybag
          • Nov 2018
          • 13
          Let me know if I need better pics or different angles. Thanks again for the help
          • Shibbybag
            • Nov 2018
            • 13
            Are these pics ok or you need something different?
            • Chivo77
              DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
              by Chivo77
              hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
              1- After receiving power SIO_SLP_S0# goes high and never changes.
              2-every...
              07-03-2025, 09:20 AM
            • dicky96
              RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
              by dicky96
              Hey guys has anyone come across this fault?
              MSI RTX 3080 Ventus 16GB OC
              The GPU powers up, all voltages look OK, Vcore 0.76V, Vmem 1.38V, PEX 0.95V
              Then after about 10 secs or so all voltages power back down again apart from 5V and 1.8V.
              It does not seem to be temperature related - if I power off and on immediately, it just does the same thing again
              I have a power sequence chart that says another voltage powers up after 1.8V and before PEX . It could be MSVDD but I am not totally sure
              Does anyone have a schematic...
              01-28-2022, 11:55 AM
            • malogro
              Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
              by malogro
              Hello all,
              I'm stumped on this guy, so wanted to see if anyone has any further ideas:
              Intro:
              This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
              Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
              04-14-2023, 04:44 PM
            • sefoster
              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
              by sefoster
              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
              11-20-2022, 09:29 AM
            • SONY_E-WASTER
              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
              by SONY_E-WASTER
              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
              does...
              12-26-2021, 05:46 PM
