42ls5600 backlight
  • Rickig
    • Mar 2015
    • 112
    • England
    42ls5600 backlight
    Have a 42” LG edge lit tv that has a backlight issue
    Tv comes on lights and sound for 3-4 seconds then back light shuts off.
    I have 24v out to Led driver board. 3.5v to inverter on.
    On the red wire with back light on I have 115v which drops to 24v when backlight goes out.
    8.8v on 3 of the black wires when lights on which if the light stays on long enough goes to 20v drop to 0.7ish when off. The other 3rd from right goes to about 1.5v but if light stays on long enough goes to 14v.
    The light has just come on and stayed on, have 20v on those 3 and 14v on the other still.
    Would this indicate a bad led strip or driver? I don't come across many problems with the edge lit led strips.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: 42ls5600 backlight
    Go into the settings and turn down the backlight setting to 20 if it is at 100 or 80. and see if that helps.
    • Rickig
      • Mar 2015
      • 112
      • England
      Yes I’ve just dropped to 20 and the light stays on.
      The voltages on the led driver black cables have all gone up to 27ish volts except the one that was lower, that’s sat at 22v (they increases the lower the back light setting. Assume that these are returning voltage and are being monitored by the driver and if ones lower than the minimum it shuts off)
      Slowly increase back to 100 and eventually the voltage drops to under 1v on that bank and it shuts off, The other 3 hover around 9v so assuming the led array has 4 banks of leds sharing the same common but with separate grounds and one bank is consuming too much power and as such shutting the driver off when on 100%.
      So is it safe to say that the led array is faulty?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes that is correct.
        • Rickig
          • Mar 2015
          • 112
          • England
          I’ve remove d the led array, found a replacement new on Ali express for under £20 so have ordered that.
          Found one Led not illuminating when I put voltage on it on the bank that’s dropping voltage so aaaume it’s that one thats bad but already ordered the array so will wait.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I've found in a lot of cases with edge-lit backlights it is just one bad LED that causes the problem and mostly a LED nearer to the connector. Hardly one in the middle.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • roy.zhero
              Sharp LC50LE752E no picture and backlight, indicator light is lit
              by roy.zhero
              I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
              When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
              When I hold the force-on-combination it will turn on. It then shows a perfect...
              09-20-2020, 01:57 PM
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
            • russpall
              LG 39ln540v - red light flashes twice, no power to LED driver?
              by russpall
              Hi there,
              I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
              The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
              08-27-2024, 01:07 PM
              LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
              This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-12-2024, 03:36 PM
