Samsung UN55FS9000 Half-Screen Dark/Ghosting Issue
  • MoreAckAck
    • Nov 2018
    • 6
    I have a 2015 model Samsung UN55FS9000 55" Curved UHD-TV. I am the original owner. About two months ago it suddenly developed an issue where the right side of the screen went dark. I could still see the images behind the dark but they were ghosted and laggy. I power-cycled it a few times and the issue remained. I took it down and let it sit for a few days. I researched the symptoms and purchased a replacement T-Con board for it. I installed the new board but the issue remained immediately after I powered the TV back up. The next day, the TV worked fine, no issues at all. It worked fine for a few weeks until the issue came back, same problem statement. Only this time, it cleared after 20 mins. It worked fine for a few days but then the issue came back. I ordered and replaced the main board based on advice I got elsewhere but the issue was still there on power up. I took it back down, let it site for a week and it worked fine when I turned it back on. The next day, the issue was back. Any ideas? I will try to figure out how to post pics. Thanks for any help.
    edit: The black on the right side now goes to the top of the screen, not cut on a straight line like the pics show.
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung UN55FS9000 Half-Screen Dark/Ghosting Issue
    it appears that you have the "standard" tab failure / panel issue.... :-(
    It might be salvageable depending on the design of the tabs at the side / bottom. Search the forum and read about these types of failures and how to "work around" is done... BUT don't go to fast... as the "workaround" is a "final outcome" that can't be reversed.
    • MoreAckAck
      • Nov 2018
      • 6
      This panel has the tabs on the side that look like little foil flaps and appear to just be jumpers. I had been advised elsewhere that these tabs could be removed and that would solve the issue but since it is a permanent modification, I wanted to make sure I got the same info from a reputable source, like this forum. Thanks for your help.
      • MoreAckAck
        • Nov 2018
        • 6
        Here are pics of the panel disassembled, showing the tabs. My understanding is if I cut these tabs off, all of them, the issue should be resolved? Is that correct?
        • budwich
          • Jul 2015
          • 3097
          sorry but I can't make out the tabs. The ones in question are on the side NOT the bottom or top of the panel.
          • MoreAckAck
            • Nov 2018
            • 6
            Closer pics: Edit: these are on the right hand side. I don’t know why the pictures are rotating.
            • budwich
              • Jul 2015
              • 3097
              OK, I understand now. Look closely at those tabs along that side and see if you notice anything different about one of them especially in the region where the horizontal "discontinuity" shows in the display. Either way, as you found, it is likely that the side tabs are an issue and need to be removed to save the set. The tabs are like removing tape and can be easily / gently pulled away / up from the contact points of the panel. Cutting them may leave behind material that is compromising the panel contacts if that is the underlying problem.
              • MoreAckAck
                • Nov 2018
                • 6
                Ok, so good news/bad news. I pulled the tabs off the right side and I got the whole picture back, so that's good. But now the right side of the panel is dimmer than the left. Slightly so, but noticeable to me. Is there anything I can do about that? Thanks.
                • budwich
                  • Jul 2015
                  • 3097
                  well... you have to "lose" something by removing something... just the "law of the universe"... :-) The "save" is not "perfect" so if you have "golden eyes", you will be disappointed.... maybe even more so with a curved screen. A 46in sony that I "saved" has a noticeable difference across the screen but it is useable.... and do notice it more when watched "off center". Not sure that I noticed as big a "gradient" on a sharp 70 that I saved but that was an "early success" and was more interested in the result of a working set as opposed to a getting back a "fully operational / spec'ed" set again. The owner of that set still likes it better than the samsung replacement that he tried and returned when we got his set back to "working".
                  Anyway, you might try adjusting some of the setting to try to reduce the differences.
                  • angelos
                    • Dec 2012
                    • 573
                    • South Africa
                    I did a save on a 40" Samsung and the results were perfect. No shading nothing. Tell me budwich what does removing the whole on side of COF IC's affect. Resolution?
                    • budwich
                      • Jul 2015
                      • 3097
                      I don't think resolution is impacted "directly" as this is a fixed pixel display and if resolution was impacted (ie. missing pixels), you would see the result especially with static displays. Uniformity is more likely an issue both in terms of color and brightness as the drivers from one side are working to provide full "range driving" across the panel all of the time... but I am not expert on the design. There are others who have more knowledge of this. I have only my experience and eyes along with readings to base this on.
                      Having said this, I could see how vertical resolution is unchanged as all horizontal lines of the display are still being driven "equally" (ie. same number of vertical tabs are working and driving the same number of horizontal lines). However, because the drivers of the horizontal signal have been "halved", the signal moving across the panel may not fully "reach" across the panel with the expected level to the opposite end which may result in some loss of horizontal resolution in some form.
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        Would you say that the remaining horizontal tabs would now work harder thus causing excessive heat which could lead to early tab failure?
                        • budwich
                          • Jul 2015
                          • 3097
                          As I think about it, maybe not. My reasoning is... basically they are working the same way as they would normally... I think it was referred to as a "push pull" design. In terms of circuit, a portion of the drive circuit is missing with the removal but its either the "push" or the "pull" (depending on timing or otherwise), but remaining circuit is still driving exactly the same circuit which hasn't changed with their removal so the "drive effort" is still the same and hence the remaining circuit works at the same rate as it would normally. My guess though. There has been relatively few reports of secondary failure (tabs on the remaining side dying). Some of the sets have been going on more than 3 years. It it possible that the initial failure is the "infancy mortality rate" for the design in some manner. After it has been reached, the remaining components may have been "cooked" so to speak and will now follow their "normal failure rate"... assuming of course, that the initial failure did not "stress" the remaining components due to some form of "heating event" or otherwise (ie. shorting / near shorting? etc) prior to removal.
                          • Xfacter
                            • Nov 2018
                            • 6
                            • U.S.
                            I just wanted to confirm, I just attempted this fix on my Samsung 15 minutes ago and it was an amazing success. I pulled off all the tabs on the left side which had a fried tab/shorted tab. I started with the bad tab,pulled it off, turned the tv on. No difference. Then I did all the tabs on that side. Instantly solved!!
                            Model number: Samsung model un58h5202afxza
                            Problem: Glitchy horizontal lines/flickering/highly abnormal picture on one side. Really hot in one spot (the bad tab)
                            Cause: Apparent water got in shorting a side tab on the left side
                            Solution: Pulled off all tabs like I was recommended.
                            ^ Just to summarize in-case someone else stumbles upon this thread on a google search. Seems to be a common problem?
                            It seems to have fixed it with no noticeable difference in picture quality..? Not sure how it looked before I fixed it, i've only seen a broken model So for this model I can confirm it as a great solution if you have a bad tab.
                            Much thanks to Budwich and Andrew F. Ali
                            Make sure to put the front bezel back on before moving it around again
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4454
                              • Italy - Milan
                              There's a reason why projects are with 2 sides of tabs, 3 years for a half working screen is not so few but here we are often talk about very recent TVs, so 3 years are nota proof of a good repair, i think something can be done better to save theese screens, not much but the goal is how to insulate only the faulty gate driver's outputs..
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                I'm happy you got your TV working again.
                                • JBC#1
                                  • Dec 2018
                                  I want to thank everybody that are helping people like me to realize nice project. I had a side tab on a Sharp lc-60LE660U defect that i removed a long time ago and was stuck with a partially repaired tv wondering what to do next. Trying to find an answer wasn't ease. Bacaps and you guys gaved me the answer to save my tv. Thanks a lot everybody.
                                  • Kjell
                                    Samsung Series 9 - BIOS issue
                                    by Kjell
                                    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                    08-01-2025, 09:15 AM
                                    09-07-2024, 05:50 AM
                                  • Nairolf
                                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                    by Nairolf
                                    I have a Samsung DM32D display.
                                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                    Here’s what I have tried so far:
                                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                    08-24-2025, 03:47 AM
                                  • vincentedel
                                    Samsung SyncMaster 740n Phase Control Issue
                                    by vincentedel
                                    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                    04-22-2025, 12:33 AM
                                  • ScHAmPi
                                    Samsung UE48JU7000 screen issue after backlight replacement
                                    by ScHAmPi
                                    Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                    I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                    07-15-2024, 05:41 AM
