Samsung UE32H5500 sound, no picture, menus only
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I've ran into a strange issue with this telly here: it turn on fine and displays perfectly, but after a while the broadcast image would just disappear (and sometimes cut back in), but it's not your "classic" case of bad LEDs: see, the audio continues to play and the OSD is also functional, this is what sets it apart from other cases of "no picture". If I change the channel, the picture comes back on and remains functional for a random amount of time before dying again.
    Reset the TV, performed a software update but the same thing happens (actually my colleague did this). Bad tuner perhaps ? It most likely requires a board swap, but it's a strange defect I haven't encountered before and I was hoping someone had the same issue at some point and had some clever fix. Haven't tested HDMI, though I believe it's fine. Any ideas ? Cheers
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Samsung UE32H5500 sound, no picture, menus only
    Oh yeah and some random reboots...the board it uses has NAND issues AFAIK, since I've ran into it before with bootloop issues...
    Wattevah...
      So when pictures disappear, the backoights are still on then?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Yes, menus are perfectly functional....hell, sometimes a speaker icon appears on screen as if it were a "radio" channel (sound only). If I change the channel up/down, the picture comes back in, almost as if its losing the "stream" or whatever you call it.....speaking of which, haven't tried switching between DVB and analog just for the sake of a complete diagnosis.
        Wattevah...
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • Dodgethis
          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
          by Dodgethis
          Hello all,
          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
          09-11-2024, 07:39 AM
        • marekk
          Samsung QE55Q67RAT no sound and bad picture when streaming
          by marekk
          I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
          I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
          Mainboard is based on pcb BN41-02695A BN94-14007B
          I will appreciate any help
          Many thanks
          Marek...
          05-29-2025, 02:23 AM
