Philips 55pfs8159 android tv bootloop
  • Diah
    • Feb 2013
    • 6439
    Re: Philips 55pfs8159 android tv bootloop
    Originally posted by samtron123
    so far I have the data on USB stick but I do not see, because television does not have a picture or menu, just stay on the light
    you make us confuse about your posting.. now you write TV stay on and nothing on screen. and you wrote and joined this thread which it is boot loop
    Hello how many thanks firstly
    unfortunately I do not get that far, I tried everything,
    I come to nothing in recovery mode no screen is displayed
    i was wondering how TV with boot loop can write data on USB as you showed us at yours posts #36 attachment
    your TV seem not boot loop you have other hard ware issue who knows.. let some one near to you check it and test it.. sorry i cant help any more
    • samtron123
      • Dec 2012
      • 77
      • germany
      #42
      Originally posted by Alschepmist
      So now with extra tool i can acces emmc with my pc as any one a dump or recovery.img file?
      Hello, I wrote about it all the time
      what are you writing me
      have you read the schematic synonymous, what a problem is when the background light is on but no picture and menu only sound is there ??
      • samtron123
        • Dec 2012
        • 77
        • germany
        #43
        Hello everybody
        is there a possibility for this problem, can one delete and reprogram the EMMC with Jtag ??
        many thanks
        • JessieNelson
          • May 2019
          I had the same one a few years ago. Unfortunately, it was burned... You are lucky if you have this one.
          • samtron123
            • Dec 2012
            • 77
            • germany
            #45
            Hello, I have a question
            which EMMC chip is there?
            Unfortunately, I can not read mine
            where did you burn?
            many thanks
            • samtron123
              • Dec 2012
              • 77
              • germany
              #46
              How do you get the NAND empty when it's full?
              • samtron123
                • Dec 2012
                • 77
                • germany
                #47
                Good day, Can connect to PC and lerren the memory
                one more question which NAND is there in the description I need
                many thanks
                • samtron123
                  • Dec 2012
                  • 77
                  • germany
                  #48
                  Hello can someone help me?
                  is it possible to create a protocol from this TV?
                  I have a usb uart silicon labs unfortunately I get from TV no protocol but only garbage as a special sign
                  many thanks
                  • rabbito147
                    • Apr 2020
                    • Holland
                    #49
                    So i think iv founded the problem a corrupted firmware i think or bootloader
                    with uart mode (iv new uart programator ) i become this code
                    FATAL ERROR! There is no bootable image on this machine!
                    Code:
                    I2C switch set as 1
                    --------- I2C Initialization ----------
                    I2C_INIT: I2C-2 bus
                    I2C_INIT: I2C-1 bus
                    I2C_INIT: I2C-0 bus
                    DDR reg 0xF7CB0BAC value : 0x00021421
                    DDR reg 0xF7CB0C00 value : 0x00004031
                    leakage info 464.
                    set Vcpu to 1300mV, default setting by hardware.
                    set Vcore to 1150mV, default setting by hardware.
                    flash_ts_init() success.
                    RDKDMP BG2Q [Oct 27 2017 18:04:12]
                    Pinmux configuration:
                    GSM 0xf7fcd040 0x009c0261;
                    0xf7ea0014: 00000072 00240611 00000253 1249008a
                    0xf7ea0028: 01249492 00000048 1ca54009 0430e44d
                    0xf7ea003c: 00000000 00000000 0000001f 63c06a52
                    Clock configuration:
                     VCO_B     frequency 1620
                     AVPLLB[4]   frequency 300
                     AVPLLB[5]   frequency 800
                     AVPLLB[6]   frequency 1680
                     AVPLLB[7]   frequency 610
                     cpuPll     frequency 1200
                     memPll     frequency 1500
                     sysPll     frequency 800
                     dClk      frequency 375
                     cpuClk     frequency 1200
                     sysClk     frequency 400
                     drmClk     frequency 400
                     cfgClk     frequency 100
                     gfxClk     frequency 400
                     zspClk     frequency 400
                     perifClk    frequency 200
                     pCubeClk    frequency 610
                     vScopeClk   frequency 610
                     nfcEccClk   frequency 100
                     vppSysClk   frequency 400
                     appClk     frequency 800
                     gfx3DCoreClk  frequency 420
                     gfx3DSysClk  frequency 400
                     arcRefClk   frequency 400
                     vipClk     frequency 400
                     sdioXinClk   frequency 200
                     sdio1XinClk  frequency 200
                     gfx3DShClk   frequency 420
                     avif0Clk    frequency 300
                     avif1Clk    frequency 300
                    [00,sd00] bootloader: part1(start=0, blks=1, version=201710271804), part2(start=
                    0, blks=1, version=000000000000)
                    [01,sd01] fts: part1(start=32, blks=32, version=201710271804), part2(start=32, b
                    lks=32, version=000000000000)
                    [02,sd02] recovery: part1(start=64, blks=120, version=201710271804), part2(start
                    =64, blks=120, version=000000000000)
                    [03,sd03] tzk_recovery: part1(start=184, blks=8, version=201710271804), part2(st
                    art=184, blks=8, version=000000000000)
                    [04,sd04] factory_setting: part1(start=192, blks=128, version=201710271804), par
                    t2(start=192, blks=128, version=000000000000)
                    [05,sd05] itm: part1(start=320, blks=128, version=201710271804), part2(start=320
                    [06,sd06] boot: part1(start=448, blks=24, version=201710271804), part2(start=448
                    , blks=24, version=000000000000)
                    [07,sd07] tzk_normal: part1(start=472, blks=8, version=201710271804), part2(star
                    t=472, blks=8, version=000000000000)
                    [08,sd08] system: part1(start=480, blks=1600, version=201710271804), part2(start
                    =480, blks=1600, version=000000000000)
                    [09,sd09] user_setting: part1(start=2080, blks=960, version=201710271804), part2
                    (start=2080, blks=960, version=000000000000)
                    [10,sd10] cache: part1(start=3040, blks=896, version=201710271804), part2(start=
                    3040, blks=896, version=000000000000)
                    [11,sd11] firmware: part1(start=3936, blks=64, version=201710271804), part2(star
                    t=3936, blks=64, version=000000000000)
                    [12,sd12] factory_data: part1(start=4000, blks=32, version=201710271804), part2(
                    start=4000, blks=32, version=000000000000)
                    [13,sd13] userdata: part1(start=4032, blks=3328, version=201710271804), part2(st
                    art=4032, blks=3328, version=000000000000)
                    get macaddr from fts:
                    cpu id:38bdc6b3 5359eb9c
                    macaddr=00:B3:53:59:EB:9C
                    tzk boot with normal mode
                    start to kick off SM CPU: start 0x3ff0449c, size 63216
                    SM CPU is kicked [ of f .
                     L 1as]It(pSoMwe)r:m eondte eirs mnaoint
                    St[a nd b y 6]W(SM): Entering adc_init.
                    [   10]W(SM): Leaving adc_init.
                    [   13]W(SM): PWM Initialized
                    [   16]I(SM): begin to run tasks
                    [   509]W(SM): Joystick connected
                    [3.019337] TZ CPU0 ERROR[tz_sw_verify_image:75] verify image fail, src=0x19c0000
                    0, len=0x004c0c00, dst=0x19c00000GIH magic num is not correct (0x482a4d49 != 0xe
                    ea8f2bc)!!!
                    tbdzz---- Img_Ld_And_Start error! Spinning now!
                    œëYS³Æ½8[   0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state
                    =0x0
                    [  278] image verified, start at 0x00920000...
                    tz kernel starting... MV88DE3114(BG2Q)-A1 total 4 cpus, v2.0.0.21, Aug 5 2014 1
                    4:39:52
                    0321[  333] start_bootloader
                    UªULAUNCH_ITM is set to zero
                    board_number = 6
                    uiBoot = 0
                    I2C switch set as 0
                    Hello, I'm net here but have the same TV and the same problem. Mine also reboots on the Philips logo. Did you even fix this ?
                    (How did you get the logs ?)
                    Danke
                    • samtron786
                      • Aug 2016
                      • 170
                      • germany
                      #50
                      try with win 7 32 bit usb uart silicon
                      • samtron786
                        • Aug 2016
                        • 170
                        • germany
                        #51
                        Win XP
                        • samtron123
                          • Dec 2012
                          • 77
                          • germany
                          #52
                          Hello, together give new version of Youtube for philips 55pfs8159 ??
                          many thanks
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4465
                            • Italy - Milan
                            #53
                            is it a problem of every Android TV? I have an AKAI repaired at november, now i cant sell it no more because Youtube no more works..
                            • Diah
                              • Feb 2013
                              • 6439
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4465
                                • Italy - Milan
                                #55
                                Why you give me your advices? Wasn't i not a professor? I already installed that app and also others and it doesn't work... just to complete my sentence i had contacted local Akai support and after pathetic waste of time in their tests it ended up on their request for payed assistance that i obviously declined.. my *alls goes to full.. damned smart TVs
                                • RethoricalCheese
                                  Philips 40PFT4009/12 bootloop (TPN149E)
                                  by RethoricalCheese
                                  Started after unplugging power cable when TV was turned on. (remote control was lost and user didn't know where power button is located)
                                  So my first thought is firmware corruption.
                                  Tried autorun.upg and upgrade_loader.pkg on 16GB FAT32 MBR formatted USB stick but neither did anything. Maybe I just don't understand how to start them.
                                  When USB inserted and TV plugged in, it just starts up and continues bootlooping. When USB plugged in and I hold down power button when plugging TV in, it just doesn't do anything.
                                  Attached boot dump (at the end it just restarts...
                                  03-03-2024, 01:44 PM
                                • rascao
                                  iMAc A1418 Board 820-00034 some kind of bootloop
                                  by rascao
                                  I have a iMac A1418 board 820-00034, the problem is when the board is cold i can get to the mac os log in for like 1 min and then start the bootloop, but is a fast bootloop sometimes i can just see the apple logo for 1 sec and keeps doing it until i un plug the power, if i try to turn on again the bootloop continues, if i let the board un plug for 15 or 20 min i can turn on again and log in on Mac os but the bootloop start again under 1 min.
                                  I try to get to the recovery and i can, when try to install a new mac os it starts loading the usb and then start the bootloop,...
                                  10-17-2024, 02:33 AM
                                • DutchDIY
                                  Philips 60PFL8708S/12 Android Upgrade Kit Issue (Pictures Inside)
                                  by DutchDIY
                                  Happy Holidays everyone!
                                  Here I have a 60PFL8708s/12 that I am trying to revive by installing the 996597007730 Android upgrade kit;
                                  The kit has been installed and I have followed the instructions to the letter, however upon powering on the tv with the USB stick and the files needed on there, instead of seeing 'Update in progress' all I am seeing is a black screen (backlight is fine). Also before turning on the tv, the white LED on the bottom of the tv is flashing around 60 times, before it going solid (standby mode), then I wake the tv with...
                                  12-24-2022, 08:23 PM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Grut
                                  JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                                  by Grut
                                  My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                                  Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                                  When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                                  Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                                  11-15-2024, 03:12 AM
