Replacing heatsink on TNPA4782AB board to use as a TNPA4782AF board
  • iampivot
    • Nov 2015
    • 24
    Hi, I have a working SC board TNPA4782 AB from a panasonic G10, which I'd like to use in a V10, which take the TNPA4782AF board, which, from my understanding, is the same as the AB board, just with smaller heat sink due to the V10 being a thinner case design.
    Am wondering if replacing the AB heatsinks with the AF heatsinks would work, just causing the board to require a bit better airflow?
  • boydsc
    • Jul 2018
    • 10
    • US
    Re: Replacing heatsink on TNPA4782AB board to use as a TNPA4782AF board
    I was wondering, Is that the only differences in the boards with different letters ?
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Noodneek
      Replacing all the caps on the BenQ SW2700pt's power board didn't help...
      by Noodneek
      My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
      I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
      08-30-2024, 12:52 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • MacGyver's paperclip
      what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
      by MacGyver's paperclip
      TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
      07-01-2023, 12:12 PM
