Panasonic TX-P42G10B SC board failure?
  • Bullseye
    • Oct 2018
    Posted earlier today but post seems to have gone missing so here's the gist of it:
    My TV is showing a 5 blink error code which, from what I have gleaned from the Internet, suggests an SC board failure. My meter, set to continuity, bleeps if I connect to the two probes of the SC2 connector. Is this a short to ground? Has the SC board failed?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TX-P42G10B SC board failure?
    Post pictures, please.
    • foxyUK
      • 35
      Is the board disconnected at SC2? Have you found the Panasonic troubleshooting guide for your model? (they are all there if you search hard enough).
      In general, find the IGBTs on the SC board and check for short circuits between the outside or outside and centre pins. Any short means at least one is dead (they are wired in parallel).
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
