Probleme. With powder 17PW20 v2 in TV Hitachi L32H01EA
  • moateez
    • Jun 2014
    • 119
    • algeria
    hello friends
    Ineed schematic for this power
    My TV is just red led with 3.3v and 5 v on standby
    ***no 24 v and no 12v
    Big capasitor is 390 v big IC number on power is IC 807 his referance is KA3525A
    Please help
  • moateez
    • Jun 2014
    • 119
    • algeria
    Re: Probleme. With powder 17PW20 v2 in TV Hitachi L32H01EA
    Please help
    • moateez
      • Jun 2014
      • 119
      • algeria
      Iam still reserching for the problem
      • moateez
        • Jun 2014
        • 119
        • algeria
        Friends please help
        • R_J
          • 9588
          5 seconds on Google I located the schematic. Check if you have ST_BY on PL803 pin 6, This is the power supply ON command from the main board, 1.7 volts = standby, 0 volts = power supply on
          • moateez
            • Jun 2014
            • 119
            • algeria
            pin number 6 from PL803 is 0 Volt sir
            please help me ihave 3 days iwith this tv
            • R_J
              • 9588
              Check the voltage on ic807, pin #15, You should have about +12 volts.
              • moateez
                • Jun 2014
                • 119
                • algeria
                Yes sir in pin 15 from IC 807 ihave 13v now what i should do??? Please. Iam waiting for you sir
                • moateez
                  • Jun 2014
                  • 119
                  • algeria
                  Sir when i make short in Pl811 (sw2)
                  Big capasitor is 327 v and pin 15 from IC 807 is 0v
                  • moateez
                    • Jun 2014
                    • 119
                    • algeria
                    i will replace Ic807 and see Ka3525 what you say about it
                    • moateez
                      • Jun 2014
                      • 119
                      • algeria
                      SG3525 or SG2525 and i will by TNY266 the switcher
                      • R_J
                        • 9588
                        If you still have 3.3v & 5v standby, tny266 will be ok.
                        • moateez
                          • Jun 2014
                          • 119
                          • algeria
                          yes sir i have it
                          then the problem is in ic807?
                          • moateez
                            • Jun 2014
                            • 119
                            • algeria
                            i have replace Ic807 and the same Probleme
                            please follow me
                            • R_J
                              • 9588
                              What is the voltage on C826?
                              Did you check the fet's Q813 & 814?
                              Do you get any voltage at all on secondary capacitors like C863, C852, Cc806 Etc.
                              If you can, post good quality (in focus) pictures of the power supply board that would help
                              • moateez
                                • Jun 2014
                                • 119
                                • algeria
                                Sir all capaitors are 0V
                                Q813 just 390 in pin 02 . 1 and 3 =0v
                                Q814 0 v
                                like picteur
                                • R_J
                                  • 9588
                                  There are two blue square capacitors between the heatsink and transformer, check if they are bulged, they might be open. The sides should be flat and smooth, I suspect one is bad
                                  They should be 15nF 650v (replace them with 15nF 1000V)
                                  They are C877 and C878 on the schematic
                                  This schematic might be closer
                                  • moateez
                                    • Jun 2014
                                    • 119
                                    • algeria
                                    Yes sir i see themi have olredy test ghrme like testing daiode they give 570ohm in side i when i flip pins of multimiter they give 0 i think is good but i will replace thel and tell you
                                    • moateez
                                      • Jun 2014
                                      • 119
                                      • algeria
                                      I cant find in my lab tomorow i will by 2 and see
                                      Ihave change the place of c877 to c878 and c878 to c877 but same probleme
                                      • moateez
                                        • Jun 2014
                                        • 119
                                        • algeria
                                        ihave replace the 2 capasitors but same probleme
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • wolf1976
                                          hitachi 50hk5600 problem with display
                                          by wolf1976
                                          hi
                                          i have the above tv and the display starts distorts the display at only in applications like you tube
                                          after and on the didital channels
                                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                                          09-13-2025, 02:26 PM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
