Magnavox 19 inch blacks out loses picture won't turn off
  • frafreg
    • Apr 2017
    • 11
    • US
    I have a Magnavox 19 inch model 19MF338B that turns on fine and after about 10 minutes the picture will go black and I hear a high pitched tone. At that point, I can't turn the set off from the switch on the set or the remote. If I unplug the set and plug it back in, it works fine again for a little while. Sometimes it will fix itself and the picture and sound come back. I tried using the component input and the HDMI input with the same results. I also replaced the cable box which did not fix the problem.
    I'm not sure if the problem is the main board or the power supply which includes the inverter. I would appreciate any help you can give me to troubleshoot this problem. Thank you in advance.
    Frank
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
