LG 60PN6500 Plasma, does not power on, red light stays on.
  • guillaumeber
    • Sep 2018
    Hello! New here, hope I can bring my TV back to life!
    My LG 60PN6500 TV suddenly died. The front small red LED stays on. The POWER button either on remote or on TV doesn't to anything.
    I've tried troubleshooting it, but I'm a bit new to TV repairs. My main board, the one with the different outputs is getting it's 5.2 volts on the pins they should and also it's 17volt.
    There is M_ON and other pins that I don't know how to test.
    When I disconnect the main board from the power supply, I can hear a relay clicking and a kind of hissing sound comming from the the 2 other big modules on the side that looks like other power supplies. I think those modules are called YSUS board but I have NO IDEA what they are for hehe, sorry.
    Where should I be looking for? I'm pretty handy with a multimeter but new to TV, so some help might help!
    thanks!
    G.b.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 60PN6500 Plasma, does not power on, red light stays on.
    We need to seem clear, focused close up photos of the PSU and the connectors and the other boards as well.
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • lapfix
      HP OMEN NO power no light
      by lapfix
      HP OMEN : DAG35DMBAD0
      NO power ,no short ,no corrusion
      Consumption : when charger plg in = 0.004 amp
      Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
      when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
      No light at power button led
      All coils resistances :
      Pl 2001 =3v measured with kohm.
      pl 2004 = 5v measured with kohm
      pl 6001 = 49.7ohm
      pl 4012 = vccsa = 24.4 ohm
      pl 3001 =...
      11-03-2025, 07:48 AM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
    • russpall
      LG 39ln540v - red light flashes twice, no power to LED driver?
      by russpall
      Hi there,
      I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
      The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
      08-27-2024, 01:07 PM
