Philips 42PFL4307H/12 : No Screen , vertical gray stripes
  • Terrotiste
    • Feb 2018
    • 32
    • France
    Hello everyone ,
    Holder of a TV Philips 42PFL4307H / 12, I find myself overnight with a TV that no longer displays the images, and against the sound (checked with a laptop connected to HDMI on the TV)
    I specify that the backlight works because I see the screen that lights up and I discern on the screen vertical stripes of gray colors in degraded mode of gray, interspersed with black stripes.
    In addition, but may be the fruit of my imagination but I have the impression that the bands are not necessarily always in the same places.
    Which track should I follow?
    Thank you
    Best regards
    JM
  • mmartell
    • Oct 2013
    • 3189
    Re: Philips 42PFL4307H/12 : No Screen , vertical gray stripes
    Audio or no audio ? I would suspect main board if no audio.
    • Terrotiste
      • Feb 2018
      • 32
      • France
      Hello
      Thank you for your answer
      Of memory, because almost 1 year ago that I did the test, the sound was present when I plugged a portable PC on the source HDMI
      This means that the motherboard is hs?
      Thank you for your help
      Cordially
      Jérôme
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Audio? Yes? I would suspect T-CON Bd.
        • Terrotiste
          • Feb 2018
          • 32
          • France
          Hello
          Audio is Ok with Pc connect on HDMI
          Cordialy
          • Terrotiste
            • Feb 2018
            • 32
            • France
            Hello
            I re-open this subject. As you advised me, I changed the card tcon TV and always the same vertical gray bars on the screen .... like the photo ...
            Another search track? Slab or motherboard?
            thank you and have a good weekend
            Jerome
            • halen
              Hisense H55U7B vertical stripes
              by halen
              I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
              1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
              2. Connected only left side of LCD to tcon, big stripes
              3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
              Where could be problem?
              Tcon RSAG7.820.7932/ROH
              Main board RSAG7.820.8698/ROH
              Jan
              06-18-2025, 03:58 AM
            • ahoonid
              MacBook A1990 vertical stripes on external screen
              by ahoonid
              Hey everyone,
              I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
              The board is neat. Not opened before for sure. Just a little dust, nothing more.
              Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
              06-20-2025, 08:54 AM
            • Raulnn
              Lg 55LB700V with vertical stripes
              by Raulnn
              good night! I pass photos of this tv with vertical stripes. what problem could it be? panel or tcon? the tcon of this model is integrated into the panel. Let's see if they can tell me what to do to see if it can be fixed. the vertical stripes have a certain pattern, because there are some equidistant....
              04-09-2023, 04:10 PM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • kevinman
              KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
              by kevinman
              Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
              12-17-2023, 06:22 AM
