Vizio M65 Everything works just not at the same time-
  • juliusvichinsky
    • Aug 2018
    • 5
    https://youtu.be/c1d8HeIPbnM
    Here is a video I recorded. The "clicking sound" is my 6 year old so disregard that.
    As you can see the lights all work just not at the same time. I have replaced the PS, Mainboard, Tcon and have tested all leds. I am wondering if maybe there are some bad caps on the PS that is causing this to happen but I am clueless. I have repaired about 15 tv's so I am familiar enough with the typical troubleshooting but at this point I am lost. Any suggestions are welcome.
    Also this issue was prior to my starting the update. I was told by someone the update would fix it.. it did not.
    Also I have lowered the LED backlight down and the brightness.. Also shut off any kind of adaptive lighting. Still the same issue.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Vizio M65 Everything works just not at the same time-
    This issue can't be the main or tcon. To me its either the LEDs, the LED driver board or something in between these two (bad contact, something shorting out)...
    • R_J
      • Jun 2012
      • 9625
      It is likely the led driver board, what is the complete model number or what is the led driver board number?
      is it 0171-2471-0103 or 0171-2471-0122 or label number 3665-0072-0111(2A)
      • juliusvichinsky
        • Aug 2018
        • 5
        I have already replaced out the driver board and the same problem exists. Possible two bad boards...
        • R_J
          • Jun 2012
          • 9625
          Well there is nothing left if you replaced ALL the boards, how did you test the leds?
          • juliusvichinsky
            • Aug 2018
            • 5
            Well as it turns out your feedback was all helpful. I started from point A again and went item by item. I found that the LED driver board I ordered was not the correct one. The difference of 1 number in the middle of the secondary board number (so the stamped board was identical). This board is not compatible and so I have ordered a new board. Ultimately my own fault for not double checking. I hope the correct board will resolve the issue.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              good luck and report back when you get the new driver board!
