Sharp LC-70LE750U Horizontal Lines
  • teebee65
    • Sep 2018
    • 6
    My Sharp LC-70LE750U TV is having an issue with Horizontal Lines. I have read several post regarding the side tabs. Not sure if this would be my issue or what. I understand the T Con board would be related to Vertical Lines only and since this is Horizontal lines the issue would either be a bad LCD Panel or the side tabs. I will include images to see if someone can identify the issue. One more thing to add, the dark shadowed lines flickers in different parts of the screen. The thin colored lines sort of flicker and changes colors but normally stays in the same location across the screen
  • teebee65
    • Sep 2018
    • 6
    Re: Sharp LC-70LE750U Horizontal Lines
    Additional info. Trying to figure out which side could be the problem if it is the side tabs. Pictures below indicate the sides I disconnected the bottom ribbon cables
    Disconnected Bottom Left Side Cable (facing front), left picture is dark with lines across the whole screen. Also while video is playing, dark lines flickering randomly from top to bottom of screen. Right side of screen appears clear in background of the dark flickering lines.
    Reconnected Left Cable and
    Disconnected Bottom Right Side Cable (facing front), right picture is dark and lines does not go all the way to the left side of screen. No flickering of dark lines. Left side picture pretty much clean and bright image
    • teebee65
      • Sep 2018
      • 6
      One more example of issue via youtube link I uploaded
      https://www.youtube.com/watch?v=d9lrpnaNyrM
      • neilc6
        • Nov 2015
        • 1550
        Might want to go through this thread. Fix could be to remove the right side drivers.
        https://www.badcaps.net/forum/showthread.php?t=49281
        • teebee65
          • Sep 2018
          • 6
          Ok so it does seem to be the right side drivers and NOT the panel?
          When you say right side, are we talking right side facing the front of the screen. Don't want to undo the wrong side
          • neilc6
            • Nov 2015
            • 1550
            Never have done this repair personally but have gone through that thread. Dont think there is much to lose even if it is a bad panel. The lines dont go all the way across so likely the side drivers. Remove the driver boards from the bad side. Your pictures look very similar to those posted on that thread.
            • teebee65
              • Sep 2018
              • 6
              I am going to do it, I am just trying to confirm which side I need to do. It was mentioned right side. Not sure if they mean looking at front/right or looking at rear/right
              • neilc6
                • Nov 2015
                • 1550
                From your reference you said the left side facing the screen is good with the right side disconnected. That means the right side is bad and should be removed.
                • teebee65
                  • Sep 2018
                  • 6
                  Thanks to this board I was able to remove the side tabs on the right side and bring my TV back to life. Cleared all the horizontal flickering lines. Unbelievable how cutting wires on a TV makes it work.
                  Now to try and figure how to get a thin dotted vertical line right down the center removed. This vertical line was there before removing the side tabs. Had nothing to do with my other issue. Sometimes the vertical line is more noticeable than others depending on the darkness or lightness of the picture. Hopefully there is a fix for this
                  • neilc6
                    • Nov 2015
                    • 1550
                    Vertical lines are usually panel problems. You can try pressing down on the tab bond for that section.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4456
                      • Italy - Milan
                      If the line is unstable then check the boards especially mainboard for pieces of metal that touches under it on the solderings..
                      For the first fault there is a method not desctructive that works, is more complicate anyway.
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • jaco2d
                        Sharp 50bj2ke horizontal lines
                        by jaco2d
                        This is only my seond post and so far i am very impressed with the forums.
                        I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                        The small white box thing in the pics is not the tv its a reflection from the window
                        Any suggestions...
                        11-01-2022, 04:45 PM
                      • ggil44
                        Sony XBR-65X750D Horizontal lines bottom of screen
                        by ggil44
                        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                        05-30-2023, 07:51 PM
                      • Rozp
                        70LE660U dark cloud or black screen with sound.
                        by Rozp
                        Hello Everyone,
                        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                        08-29-2023, 05:25 PM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA Horizontal lines
                        by x_orange90_x
                        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                        07-15-2023, 05:06 AM
