Samsung Plasma PN60F5300AFXZA
  • landyboy
    • Apr 2013
    • 443
    I picked up a 60" Plasma seller said stopped working after storm.... Nothing visible on any of the boards. Does not power on. I do have 5v standby voltage at thee input to the Main Board. I have read where one of the EPROM's on the main board is a known issue??
  • landyboy
    • Apr 2013
    • 443
    Re: Samsung Plasma PN60F5300AFXZA
    Is there a way to force the set on to isolate to the main?
      These units do not have the "EEPROM" issue that affected 2008/2009 Samsung sets.
      Since your set has an integrated control board (built onto the main board) there is not a great deal you can do to test this.
      If you have established 5V stby but no activity from main board, e.g. not toggling the PS ON line to the power board, you will have to replace the main board first. I am assuming you do not know about diagnosing a main board as it is not a task for a beginner.
      • landyboy
        • Apr 2013
        • 443
        Your assumption is correct. I will order a main board and start there. Thanks!
        • landyboy
          • Apr 2013
          • 443
          A few places advertise a replacement IC EEPROM for IC801 as a fix for these boards. Any way to test or jumper the IC801 to check to see if it is the issue? Or is this bad info?
            not an EEPROM. It's SPI NOR Flash.
            But no way to "jumper" it. Just need to replace it if it's the issue.
            Nothing else you can do to test it without detailed knowledge of how these work unfortunately.
            • landyboy
              • Apr 2013
              • 443
              Thanks, I ordered one lets see what happens.
              • landyboy
                • Apr 2013
                • 443
                OK that did not work. Could a bad YSUS board cause this condition?
                • landyboy
                  • Apr 2013
                  • 443
                  I also want to add that I do not have a standby light in the front of the TV at any time.
                  • R_J
                    • 9633
                    do you have any voltage on the PS-ON pin on the power supply, monitor the pin then press the power button to see if there is a change.
                    If you are getting a change on pS-ON, disconnect CN802 and moitor the VS pin, does it have any voltage? It won't sty up due to OVP, to test it you need two 60watt incandescent lamps connected in series across VS & ground to act as a load.
                    To test part of the power supply (not the VS supply), disconect CN801 from the main board and check the voltage on PS-ON (pin1) if there is 0 volts, connect a 1k resistor between 5v stby and PS-ON, If there IS 5 volts on PS-ON, then ground PS-ON. see if you get D15v or D5.3
                    • landyboy
                      • Apr 2013
                      • 443
                      Voltage on PS-ON 2.8V No Change when power pressed. Pulled CN801 4.2 volts on PS-ON Grounded PS-ON and got 15v on D15
                      • landyboy
                        • Apr 2013
                        • 443
                        Would this indicate a good power supply and possibly a bad Main?
                        • R_J
                          • 9633
                          I could be, the main is what controls that pin so either something on that control line. You said you replaced th spi flash chip so I don't really know what else it could be.
                          That other spi ic IC2001 is for a different version of the board
                          • landyboy
                            • Apr 2013
                            • 443
                            Yes i saw that as well but I could not locate ton the board either. I guess I will try to find a mainboard and see what happens.
                            • R_J
                              • 9633
                              where did you get your flash ic? maybe you have the one for ic2001 and not ic801, is that possible?
                              on this board ic2001 is above the crystal
                              • landyboy
                                • Apr 2013
                                • 443
                                I order it from shop Jimmy verified it is the IC801
                                • landyboy
                                  • Apr 2013
                                  • 443
                                  Follow up. Ordered main board it fixed the problem.
                                  • Asraf Atb
                                    by Asraf Atb
                                    01-27-2025, 05:02 PM
                                  • mrautom8
                                    Samsung TV UN75H6350AFXZC main board schematics?
                                    by mrautom8
                                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                                    I love a good logic puzzle but getting lost without any schematics.
                                    No shorts on ANY capacitor main board.
                                    Thermal camera shows 3.3V inductor getting warm instantly but...
                                    10-19-2025, 06:32 PM
                                  • alltvrepairs
                                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                    by alltvrepairs
                                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                    Any one met this problem in the past?...
                                    10-08-2025, 07:34 AM
                                  • Dani_2024
                                    by Dani_2024
                                    10-28-2024, 05:06 PM
                                  • ygorsan
                                    by ygorsan
                                    🧩 Problem Summary:
                                    • I
                                    07-28-2025, 08:34 AM
