I picked up a 60" Plasma seller said stopped working after storm.... Nothing visible on any of the boards. Does not power on. I do have 5v standby voltage at thee input to the Main Board. I have read where one of the EPROM's on the main board is a known issue??
Samsung Plasma PN60F5300AFXZA
Re: Samsung Plasma PN60F5300AFXZA
These units do not have the "EEPROM" issue that affected 2008/2009 Samsung sets.
Since your set has an integrated control board (built onto the main board) there is not a great deal you can do to test this.
If you have established 5V stby but no activity from main board, e.g. not toggling the PS ON line to the power board, you will have to replace the main board first. I am assuming you do not know about diagnosing a main board as it is not a task for a beginner.Last edited by tom66; 09-02-2018, 02:40 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
not an EEPROM. It's SPI NOR Flash.
But no way to "jumper" it. Just need to replace it if it's the issue.
Nothing else you can do to test it without detailed knowledge of how these work unfortunately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
do you have any voltage on the PS-ON pin on the power supply, monitor the pin then press the power button to see if there is a change.
If you are getting a change on pS-ON, disconnect CN802 and moitor the VS pin, does it have any voltage? It won't sty up due to OVP, to test it you need two 60watt incandescent lamps connected in series across VS & ground to act as a load.
To test part of the power supply (not the VS supply), disconect CN801 from the main board and check the voltage on PS-ON (pin1) if there is 0 volts, connect a 1k resistor between 5v stby and PS-ON, If there IS 5 volts on PS-ON, then ground PS-ON. see if you get D15v or D5.3Last edited by R_J; 09-11-2018, 07:17 PM.Comment
I could be, the main is what controls that pin so either something on that control line. You said you replaced th spi flash chip so I don't really know what else it could be.
That other spi ic IC2001 is for a different version of the boardLast edited by R_J; 09-12-2018, 06:31 PM.Comment
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by dokmaHello forum!
This is my fourth post so I will try to start on the right foot by doing it properly right off the bat. I bought this plasma faulty to play around with. The main board is completely burnt. When I unplug everything but the power supply and the main board and I plug in the power chord I get plenty of smoke from the main board.
Now, the model of the TV is a bit of a detective work. I couldn't find the model of the TV anywhere on the back cover or inside so I deduced it from the main board codes. SO I THINK this is PS50Q97.
Now, since the board is... -
by Lee M.When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
