LG - 42lf5000 weird image
  • anna1980
    • Mar 2016
    • 40
    • holland
    A friend of mine just sent me this picture of his tv.
    It a 42lf5000 from LG
    I havent seen it yet, since hes going to take it to me this weekend.
    But by the looks of it, it doens't look like a panel problem.
    I think it should be something like a tcon problem. Since these things could have something like the dreaded as15/as19 chip, could this be a case of malfunction chip ?
    Added
    I saw it had the intersil i7868a chip. Can anybody confirm it is interchangable with an as19
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4451
    • Italy - Milan
    Re: LG - 42lf5000 weird image
    From my notes it is...
    • noledud
      • Dec 2013
      • 413
      • united kingdom
      Hi That looks like an AS15 fault iv had to sort loads of them over the years, remove the TCON and replcae the AS15 chip or if you cant swap it out search for an AS15 repair service on ebay
      • viktorkane
        • Jul 2018
        • 32
        • albania
        difekt t-con find another
        search in ebay
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4451
          • Italy - Milan
          noledud you don't read well the posts, She said it has i7868a chip...
          If She (or he?) is willing to try the chip swap.. IT IS ALWAYS THE BETTER WAY than replacing tcon with a SURELY used one that can fail shortly..
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • mich6el
            Imac 2020 a2115 no image after reblays T2 Security chip
            by mich6el
            Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards,...
            04-22-2025, 02:05 PM
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
