philips 55pfl4508k/12 hangs on logo "PHILIPS"
  • kiko1
    • Apr 2016
    • 48
    • croatia
    I have philips 55pfl4508k/12 that freezes on start logo...no response to RC or tv buttons or inserted USB with FW....
    maybe FW will boot these ones up ...I have 3 of them with exactly this same symptom.
    Is there any other possibility to upload FW other than USB?
    anyone?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: philips 55pfl4508k/12 hangs on logo "PHILIPS"
    This reads like you have a software issue and may have to reprogram the EEPROM on the Main Bd.
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • alfonzzo
      Philips TV 40PFL3148H/12 keeps restarting on the logo
      by alfonzzo
      My Philips TV 40PFL3148H/12 keeps restarting as soon as the Philips logo is displayed, as soon as I plug it. The remote doesnt have any effect on it anymore, plus no red light on the tv panel as usual.
      After contacting their support, they sent me a file to update the firmware from usb but without success (8gb 2.0 drive formatted in fat32).
      Then they told me that it was a hardware problem.
      Here is a video of the problem : https://streamable.com/8ixf1u
      Thanks for your help...
      08-10-2022, 09:00 AM
    • irepair559
      Hp envy x360 2021 model Freezes on hp logo won't do anything !
      by irepair559
      Hello guys ok got a newer hp envy x360 15 -ey0013dx laptop ryzen 5 Amd video.. but will not boot into any windows usb installer, tried diff known good m2 ssd from another hp amd device.. tried taking its ssd and putting it into another hp laptop and installed windows fine ( didn't let it reboot the first time so I can use it ) that didn't work.. flashed latest bios through usb.. first it said flashing boot block that completed..then recovering bios , then flashing bios and TPM.. is that normal bios procedure ? but anyhow even after that still same issue.. stuck on hp logo ...then would either...
      11-17-2023, 12:18 AM
    • Verlengsnoer
      Bios splash/logo change
      by Verlengsnoer
      at firs, i hope this is the right place to post my question.
      Im looking for a tool to change the bios logo.
      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
      i know that HP has a build in option to change the splash logo.
      but i want to change the manufacturer logo to an own logo.
      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
      10-28-2022, 09:52 AM
    • abajor
      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
      by abajor
      Having this very weird issue.
      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
      I swapped with a working screen from an A2141 waiting for parts.
      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
      04-27-2024, 01:37 PM
