Samsung 65" curved screen won't turn on, power light blinks 6 times
  • Keshenatech1
    • Apr 2018
    • 149
    I'm working on a Samsung UN65JU6700FXZA, a 65" curved screen model about 2 1/2 years old. When I first got it in, I had a red standby light but it wouldn't turn on. The standby light would just flicker when I press the power button on the back or on the remote. So I ordered a replacement "used/tested good" power board on Ebay. Now when I attempt to power it up, the standby light blinks 6 times, pauses, blinks 6 times again and keeps looping until I shut it off. I verified the backlights work by unplugging the main board. Has anyone gotten a hold of Samsung's official list of what the codes mean for the number of blinks? I was just on chat with them for almost an hour only to find out they can only give that info to "authorized service personnel". I did notice the heat sink on the main board gets rather warm in a short time and I suspect it may be bad, but I also want to rule out having 2 bad power boards. Any input or suggestions would be greatly appreciated. Sorry I don't have any pictures handy at the moment. My phone is also malfunctioning. I have over 16GB free on the SD card and on the internal memory but I get a "can not save" message when ever I try to take a picture. It's an LG G5.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Re: Samsung 65" curved screen won't turn on, power light blinks 6 times
    TV unplugged, take the back off the TV, unplug the main board from the PSU and plug the TV into mains socket. The PSU should turn on by itself and the backlights should be on.
    • Keshenatech1
      • Apr 2018
      • 149
      Thanks for the reply. My original post was kind of long-winded and I may have not been very clear, but I mentioned I already did that and the back lights do come on solid with the main board unplugged.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        ok, what are the voltages on the PSU connector that goes from the PSU to the main board?
        Use the pin out name with the voltages measured.
        Like:
        PSon = 3V
        BLon = 3.2V etc...
        • Keshenatech1
          • Apr 2018
          • 149
          Unfortunately I don't have the TV in front of me at the moment. It's in the shop across town and I won't be visiting there until Thurs night so I could try to get some voltage readings then. It's a 2 level connector with the pins in close proximity so I was a little afraid to probe them with the power on for fear of shorting something out but I'll try to be careful. Do you want me to take readings with the main board connected or disconnected? I do have the original power supply board at home so I took a couple pictures of it. I zoomed in on the power output connector on the 2nd picture so you can see the pinout chart. The power supply board is a BN44-00808C by the way. I could power up the original board on my kitchen table and take some voltage readings if that will tell you anything? The confusing thing to me is I had 2 different symptoms with the 2 different power boards. The original board would only flicker the standby light when pressing the power button, but the new one gives me the 6 blinks pattern repeating. So I'm trying to figure out if my new power board is bad, or if I possibly have a bad main board and a bad power board. Main boards are expensive so I want to get some idea of what's going on before ordering a new one.
          https://www.badcaps.net/forum/album....&pictureid=806
          https://www.badcaps.net/forum/album....&pictureid=807
          • Samunggg
            Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
            by Samunggg
            I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
            I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
            09-06-2023, 06:39 PM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • kca
            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
            by kca
            Hello all ~
            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
            No picture. No sound.
            I tested all the voltages coming out of the power supply...
            10-12-2023, 05:23 PM
          • KYBOSH
            Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
            by KYBOSH
            Picked this up to resurrect.
            When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
            I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
            Sometimes the TV would produce an expanding blob on the screen before going black.
            See Video here
            I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
            Did I get another defective board or is there an issue with...
            09-16-2024, 07:48 PM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
