Samsung Plasma PN51D450A2D
  • dr3am
    • 5
    I have a Samsung 51 inch Plasma model number PN51D450A2D and it has 3 horizontal lines running through it. I have about 40 of these TV's and 2 that where working fine but the panels where broken during transportation. I gutted the 2 broken ones so I have parts. I have attached a pic. The lines are their even when I go into the Service Menu as well as on all sources. Any and all help would be appreciated. Thanks
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung Plasma PN51D450A2D
    Panel failure. The ribbons have a burnt trace on them. Unrepairable.
      Agreed, it's dead.
      • petehall347
        • Jan 2015
        • 4450
        • United Kingdom
        they are vertical ...
          It doesn't matter, both single vertical and horizontal lines are caused by panel failures.
          • dr3am
            • 5
            Thanks for the help!! Guess I have a ton of parts for sale!!!
              09-07-2024, 05:50 AM
            • xNOTx
              Verticle lines on Samsung PN42A400 Plasma TV
              by xNOTx
              Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
              [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
              04-30-2024, 04:22 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • thetonywarren
              Samsung PN51E450 Plasma Vertical Lines
              by thetonywarren
              Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
              Any help would be appreciated.....Please let me know.......
              02-14-2022, 01:23 PM
            • Rubenlily
              Samsung QE50Q67TAU - horizontal lines
              by Rubenlily
              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
              I'm no expert but I've done the tape...
              08-16-2023, 01:12 PM
