Panasonic TNPA5349AD (SN board) TC-P42S30
  • bfortune206
    Burkes
    • Sep 2015
    • 23
    Is there a replacement for a Panasonic b0echr000004 Diode? They been back ordered from Encompass for over two months.
  • bfortune206
    Burkes
    • Sep 2015
    • 23
    Re: Panasonic TNPA5349AD (SN board) TC-P42S30
    The diodes are D16673 and D16674. Right beside Q16661
      Any 10-20A, 300V, fast recovery / switching SMD diode will likely do.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
