Vizio E500i-A0, LED lamp beads, new sticky?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    In my opinion, it would be good to have a resource, maybe like a "Sticky" dedicated to individual LED application, like which LED's work on what strips. That would make it so much easier to source LED's for individual replacement! What do you all think?
    I recently traded for a Vizio E500i-A0 with sound, picture and no backlights. After testing I found two bad LED's. I replaced them with two I recently bought at ShopJimmy for LG panels. They are too white and leave a "hot spot" on the display.
    The part number on the LED strip is 6916L-1276A. Would any of you happen to know what part number LED's these use?
    Thanks everyone!
    They call me......."threadkiller"
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Vizio E500i-A0, LED lamp beads, new sticky?
    bump
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      SOLVED! I determined the problem was with the Krazy Glue I was using. It looks like it was outgassing in to the lens and causing it to become frosted right above the LED. There was also evidence of outgassing on the bottom diffuser panel right above the LED's I replaced.
      The solution was to use two-part epoxy instead of Krazy Glue to attach the diffuser lens to the LED strip and clean the bottom diffuser sheet with glass cleaner and a microfiber cloth.
      The LED's are a slightly more white in color but once assembled they are indistinguishable on the display panel. The ones I used were ShopJimmy part number sj-LG LED Ver. 1
      I'd still like to know what LED's these use and if anyone thinks an LED bead interchange thread would be helpful. Perhaps this is a start for everyone?
      • rddube
        Aspiring Expert
        • Jun 2013
        • 942
        Hey, I use ligquid plastic that responds to blue light for the leds, does a super job.
        I was also using krazy glue but that stuff adds a film on the lens (I guess it melts the plastic or something), so I decided to try the blue light liquid plastic and voila! Known brands are bondic, but I find it a bit yellowish, so I get this kind of stuff:
        https://www.ebay.ca/itm/Lazer-Bond-5...lue+light.TRS0
        Hope this helps.
        • diif
          • Feb 2014
          • 6978
          • England
          Yeah, cyanoacrylate fumes aren't so good for some plastics.
          I use the same stuff as rddube.
          I just replace individual LEDs on strips. I've bought quite a few different batches of SMD LEDs from Aliexpress and with the use of a spectrometer can see which are closer to the colour of the original. Some are spot on, others quite a way off and no good. Most are only referenced by size, some by manufacturer/model but it's China/Aliexpress so there's lying/copies/fakes. However when I'm paying between £2-£4 per 50/100 this isn't so much of an issue.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Hope this helps.
            That is awesome! ShopJimmy has something like that....but more expensive! Thanks, that definitely helps!!
            Is a spectrometer expensive? If someone is replacing a lot of LED's individually it sounds like a must have. Too bad there's not an app for that! lol
            I'm hearing more and more about counterfeit electronics....how destructive they can be and how difficult they can be to spot. That's one of the reasons I haven't sourced anything from China yet.
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • vestaviascott
              Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
              by vestaviascott
              Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
              Here's what happens:
              1) Power on
              2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
              3) Blue status light flashes for appx 4 minutes...
              07-29-2020, 06:08 AM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
