LG Plasma 60PB5600 Logic Board no light
  • fconsela
    • Jul 2018
    • 15
    Hi all - have something that I havent read about on this site.
    Have this LG thast has no video, bad Y-upper buffer (at least).
    However, when turned on - the green light on the Logic board (EBR77186601) never illuminates, no blinking either. I know the light works as when I probe it in diode mode it come on.
    Would a bad Y buffer and/or Ysus keep prevent the Logic board from coming up? This even happens when I disconnect the logic board to try and jumper EXT_AUTO_GEN (also no test patterns) - never does the light come on.
    Where to begin?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG Plasma 60PB5600 Logic Board no light
    Is the Logic Bd. getting 5V from the Y-SUS Bd?
    • olivier.gendron@gmail.com
      • Aug 2018
      • 18
      ES1432 flat cable seems to not be connected properly
      • R_J
        • 9588
        P231 does'nt look like it is connected properly either.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
