Samsung UN60D6000SF screen repair
  • Runek
    • Jul 2018
    • 4
    My tv (Samsung UN60D6000SF 60") got hit with a direct hit on the LCD screen, everything else is working, just a black screen. Is this costly to repair? It only seems to be the top layer of the screen itself.
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung UN60D6000SF screen repair
    the best you can likely hope for is to salvage the cards and sell them for some money to pay for a new tv. A panel replacement is usually the cost of a new tv IF you can even find the replacement panel.
    • Runek
      • Jul 2018
      • 4
      Where can I sell it? As most likely that's going to be my only solution at this point.
      • Runek
        • Jul 2018
        • 4
        Anyone?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Try e-bay USA
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
