LE40A656A1F - Bricked
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    I've bricked this set while updating it after it became unresponsive so I'm looking for the EEPROM bin file in order to reprogram the EEPROM.
    The set has a bad panel so I don't wish to spend money on it and consider this just an exercise.
    Mainboard MT8226 - EMMA, BN41-00974B
    Panel Samsung LTF400HC01
    EEPROM IC7004, S24C308AKH5-J508
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LE40A656A1F - Bricked
    post 2 of this thread any good ?
    https://www.badcaps.net/forum/showthread.php?t=22141
    or is set totally dead/unresponsive
    ic5004? just wondered as thats ohms list
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Thanks for the reply. Unfortunately I have truly bricked the set with the only function working being the On/Off. Set powers up using the remote but no backlight/display. Info, Menu, Mute, Power also brings on the set but again with no backlight/display. Although the remote control signals are still received by the set the only working function being the power On/Off remote button only. All the touch buttons on the set are unresponsive.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4532
        • Italy - Milan
        How it is happened this? Remember the tech terms, eeprom doesn't contain any software, that is the nand flash. How do you think you can reprogram that chip?? It needs unsoldering, reprogram with programmer, resoldering.
        In my HD i have a guide in Italian on how to update the DVB-T software through the serial cable between PC and tv using the software SV2_V07. You need Firmware T-PERLDEUC-1020.0.tvz .
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          I hate eeprom faults i usually opt for a bopard swap if possible as you say though not worth spending money on if panel fault though lets hope someone has the firmware for free pity you cant remove the old eeprom like some older samsungs that rewrite its own software back to it
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I found a guide here which gives some information on using the SV2_V07.
            I've connected an oscilloscope to the TV's serial port and at switch on there is serial data stream which I can see on the oscilloscope. So it looks as though the TV serial port is working.
            Do you know where I could find the firmware you mentioned T-PERLDEUC-1020.0.tvz .
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              did you find this forum?
              https://translate.google.com/transla...66&prev=search
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Thanks for the link. It doesn't really give me any more information than I already have.
                The SV2_V07 software says that I need Firmware T-PERLDEUC-1020.0.tvz just as David.p says but I cannot find that file. The Samsung site gives T-AMBPEUMD.exe as the update file.
                • Diah
                  • Feb 2013
                  • 6540
                  however we dont know what fault the set had and what you did to say you bricked it.. RC working its mean eeprom ok
                  T-AMBPEUMD.exe after you format the USB pin to format32 you run the exe and it will install the firmware bin format on the usb.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4532
                    • Italy - Milan
                    https://www.digital-forum.it/showthr...-02-12/page166
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      This should be the file
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Thanks for the file. Appreciated.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          hopefully the file etc will work, you maybe able to reuse the main board then in another repair etc.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            So I've successfully connected the set to my laptop via the TV's serial port and run the program SV2_V07 selecting the file T-PERLDEUC-1020.0.tvz when prompted.
                            There is initial communication but it then appears to be stuck in a continuous loop as can be seen in the screenshot attached.
                            Any idea's?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              ive had a quick look in some of the forums cant seem too find any info on this issue at all.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4532
                                • Italy - Milan
                                I don't remember well but one have to wait even some minutes until it starts to uploading...
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Thanks. Will have another attempt at it.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    I did read in the forum i downloaded the file from that the lead had to be less than 1 meter? not sure why though also is the firmware/software in the file just for ota updates etc i wasnt sure.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4532
                                      • Italy - Milan
                                      The cable less than 1m or even 1,5m with a ferrite ring.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        The cable is about 0.3 metres and the communication does appear to be OK.
                                        Using a USB to serial interface which I have used many times without any problems.
                                        • jordi90
                                          Lenovo Thinkpad 20LT-S0KL1G bricked after writing the wrong eeprom
                                          by jordi90
                                          I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
                                          Can I do something to fix it? I’ve attached photos.
                                          10-09-2025, 01:08 PM
                                        • SidneyCanadas
                                          93C46 and 93C56 EEPROM
                                          by SidneyCanadas
                                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                          06-14-2023, 01:16 PM
                                        • dmccul2698
                                          Pioneer DEX-P99rs "No EEProm " diagnostic code.
                                          by dmccul2698
                                          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                                          1). Understand the schematic and check the connections between the EEProm and DSP
                                          2). Check the functionality of the EEProm
                                          I don't know if this is the unit's problem but it's a place to start.
                                          I have little to no electronic experience...
                                          04-08-2024, 05:32 PM
                                        • edgarmg15
                                          Damaged EEPROM on TV Vizio E320-A0
                                          by edgarmg15
                                          Hi everyone
                                          I´m trying to repair a TV Vizio E320-A0 that I found in the street
                                          The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                                          The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                                          So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                                          11-19-2022, 03:46 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
