LE40A656A1F - Bricked
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LE40A656A1F - Bricked
    did you manage to sort this? i wonder if you have a bad ic and it cant write to it maybe try freezing the ics?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The IC is fine. I can read and write to the IC and verify data. Just don't have the right data file for it. Hopefully at some time it may become available. Not in a rush since the set has a bad panel anyway. Thanks.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4516
        • Italy - Milan
        Have you got a NAND flash programmer??
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Hi Davi.p, No I don't.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4516
            • Italy - Milan
            You said (1st post):
            I've bricked this set while updating it after it became unresponsive so I'm looking for the EEPROM bin file in order to reprogram the EEPROM
            i've said to you that software is not on eeprom! is on the nand flash..
            so wich type of programmer do you have?
            If it s bricked there's nothing you can do apart connect it to the PC via serial cable and try to upgrade by there.... !
            • jordi90
              Lenovo Thinkpad 20LT-S0KL1G bricked after writing the wrong eeprom
              by jordi90
              I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
              Can I do something to fix it? I’ve attached photos.
              10-09-2025, 01:08 PM
            • SidneyCanadas
              93C46 and 93C56 EEPROM
              by SidneyCanadas
              I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
              https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
              Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
              06-14-2023, 01:16 PM
            • dmccul2698
              Pioneer DEX-P99rs "No EEProm " diagnostic code.
              by dmccul2698
              Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
              1). Understand the schematic and check the connections between the EEProm and DSP
              2). Check the functionality of the EEProm
              I don't know if this is the unit's problem but it's a place to start.
              I have little to no electronic experience...
              04-08-2024, 05:32 PM
            • edgarmg15
              Damaged EEPROM on TV Vizio E320-A0
              by edgarmg15
              Hi everyone
              I´m trying to repair a TV Vizio E320-A0 that I found in the street
              The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
              The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
              So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
              11-19-2022, 03:46 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
