Question about faulty nand flash chip in Samsung TV
  • sickboy
    • Jun 2015
    • 86
    Hi, I obtained a big Samsung ps51d6900dk TV today which would switch on, display the Smart TV logo, then start cycling on and off.
    I froze IC1302 flash chip to see if this was the fault and the set stayed on. That was several hours ago now and the TV is still functioning correctly. I can turn it off and on again and it stays on every time.
    Now, my question is.. have I fixed it or is it inevitable it will do it again sometime soon? Also, while it's working, if I upgrade the firmware will that help prevent the fault returning?
    I can see these chips are available on ebay for around £60. While that may or may not be worth it for a 7 year old tv, I'm just not sure my soldering skills are up to such a job. Can anyone give any advice?
    Thanks!
  • sickboy
    • Jun 2015
    • 86
    Re: Question about faulty nand flash chip in Samsung TV
    Anyone?
    • diif
      • Feb 2014
      • 6978
      • England
      Photos always help to identify what you are talking about.
      I've bought Samsung NAND chips off ebay but they were £18 and needed replacing because of bad blocks, freezing wouldn't fix that.
      • sickboy
        • Jun 2015
        • 86
        Apologies, this is the chip in question.
        • vinceroger69
          • Mar 2012
          • 6714
          Diff do these replacement chips need re programing or do they come with the firmware on them as nand programers seem too be expensive
          • diif
            • Feb 2014
            • 6978
            • England
            I paid about £120 for my NAND programmer and buy blank chips.
            The chips I've seen on ebay are advertised as pre programmed.
            There's no guarantee freezing fixed it permanently or didn't. The NAND usually fails due to bad blocks.
            • vinceroger69
              • Mar 2012
              • 6714
              Thanks diif ive had too have a break from doing any repairs due too working loads of overtime at work, but getting back into doing repairs now and buying some new repair equipment have you got a link too the programmer you use thanks
              • diif
                • Feb 2014
                • 6978
                • England
                It's the GQ-5X programmer. It's the only sub £150 NAND programmer I found that did the Samsung NAND in the D series Samsungs.
                • sickboy
                  • Jun 2015
                  • 86
                  Hi Diif, if it turned out that I need one, can I buy one from you?
                  TV is still behaving perfectly so far though.
                  • raileanu
                    • Sep 2015
                    • 128
                    • United Kingdom
                    Va rog aveti un dump NAND pt aceasta placa am incercat cu 24C256 dar e aceasi problema se restarteaza in logo
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4545
                      • Italy - Milan
                      pezzodemmiedda, no good to hijack other one's thread..
                      • raileanu
                        • Sep 2015
                        • 128
                        • United Kingdom
                        I found a link for a good NAND dump and I fix the TV already.
                        • tranquility
                          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                          by tranquility
                          i want to repair an Onkyo TX-NR809 receiver.
                          symptoms:
                          on power on, display appears and i hear one click. enue functions is given.
                          - no hdmi output
                          - audio output not tested, but i think it is not there
                          - usb sticks are not recognized
                          if i read out the chips with display+standby button + tone+
                          both dts show only ????
                          chip is D830K013BZKB4
                          things i have done:
                          - reflow of the dts chip without taking off and reballing
                          - changed the aluminium caps without the big one with 25v because i dont...
                          08-25-2025, 01:04 AM
                        • Deeloc
                          How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                          by Deeloc
                          I have a 1tb WALRAM SSD (Photo)
                          Controller SM2259XT2G (photo)
                          Samsung memory (photo):
                          Part Number K9DVGB8J1B DCK0
                          Name V-NAND V6
                          Type TLC
                          The SSD itself is detected as 1gb, but is not initialized.
                          There is a Sata to USB adapter
                          A lot of SMI MPTool, did not flash it. compare flash fail (17)
                          K9DVGB8J1B is not listed anywhere
                          What to flash?​...
                          06-05-2024, 08:32 AM
                        • testaccgta
                          Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                          by testaccgta
                          Hi, everyone!
                          I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                          I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                          09-01-2024, 08:24 PM
                        • mizuh0
                          MSI B660M Mortar DDR4 (MS-7D42 Rev 1.1) Request for EC flash chip (W25X20CLNIG)
                          by mizuh0
                          Hi all I hope im doing this correctly,
                          I need a firmware dump for the Nuvoton NCT6687D‑M controller (EC flash chip: W25X20CLNIG) used on the MSI B660M Mortar DDR4 (MS‑7D42, revision 1.1).
                          I acquired a ch341a black to reflash my bios, and was so excited to use it that I tested it on the W25X20CLNIG 3.3v chip as I didn't have the 1.8v yet for the bios chip itself.
                          Being a total newbie I straight up corrupted the EC flash chip, and now the power button does nothing, PS_ON# does not change, and when I manually short the PS_ON# pin it immediately turns off...
                          07-23-2025, 03:52 AM
                          09-07-2024, 05:50 AM
