Vizio E601i-A3 backlighting problem
  • heartbeat
    • Sep 2012
    • usa
    Re: Vizio E601i-A3 backlighting problem
    hi had this same model with the same problem.all the voltages to the main board were correct.all the voltages on the power supply were correct,but the voltages from the power supply going to the led strips would start to come up then go back down.i decided to check the led strips with my checker and they all worked fine,so i plug the tv in and turned it on and all leds turned on so i moved the wire going to the leds and they went out.i decided to to take the strip out, i look at the socket and it looked dull inside.i took my knife and scraped the pins.it works i got it back together and it still working fine. i hope this will help you.
