Raster temporarily appears at turn-on.
  • Wizard
    • Mar 2008
    • 2296
    RCA D40W20YX1 chassis ATC221 (yeah that's old but it is best CRT condition).
    After turn on, No raster (as it should be) till picture appears then I get light washed out raster lines with picture then one by one (all three colors) fades away to normal picture.
    Plays fine for long time. I have worked on ATC221 and they don't do this like this even with related (next generation chassis (ITC222 that replaced ATC221).
    Background on repair, I had to clean out the coolant (went brown tinted), reseal on two CRTs so the issue is now taken care of. Coolant leaked onto the green CRT board but repaired the damage and clean up. Unplug any one of three CRT boards then turn on. No temporary raster, just perfect turn on.
    I might have issue on the adapter board (this what sets apart from ITC222 and ATC221), the power/deflection or small signal boards. But where? Sigh!
    Measured voltages all is good.
    Cheers, Wizard
  • bembeno
    hp 15 G3 auto turnon after shutdown
    by bembeno
    the laptop works good but it turnon automaticaly after shutdown i replaced the windows and tried to replace the cmos battery i also updated the Bios but still the same
    03-22-2023, 10:29 AM
  • Scincidae
    UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
    by Scincidae
    I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
    I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
    04-24-2022, 06:00 PM
  • IamPritesh
    Charging Issue comes back after few days ( Bios Reprogram Fixes it only Temporarily )
    by IamPritesh
    Motherboard : CSL50/CSL52 LA-E791P REV 2.0
    Issue : Charging works fine as soon as I reprogram the bios ( Bios bin file is available on this forum ) . Then after few days ..like 4-7 days, ti again stops charging and battery shows as 100% always. If I unplug the AC adapter, the laptop shuts down immediately.
    Has anyone every has similar issue ?
    Thank you everyone for this wonderful forum.
    09-08-2019, 07:36 AM
  • Ali101
    Dell Inspiron 17R 7720 "Your Battery is Temporarily Disabled", Battery LED Flashing
    by Ali101
    Hello BADCAPS Experts,
    My Inspiron 17R 7720 SE laptop can't power on with battery but only AC adapter can turn it on, if i try to charge battery with power off laptop than it flashing 4 orange flashes, then white flash, then repeat, if i open laptop connected with AC adapter with battery it showing a start-up message "Your battery is temporarily disabled. Please turn off the unit and try again when the unit is back to operational temperature" & keep flashing 4 orange flashes, then white flash, then repeat.
    When I run the F2 Setup, under battery health I get the same...
    09-12-2017, 12:28 AM
  • tbsmith
    Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
    by tbsmith
    There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
    08-11-2025, 06:15 PM
