Charging Issue comes back after few days ( Bios Reprogram Fixes it only Temporarily )
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Motherboard : CSL50/CSL52 LA-E791P REV 2.0
    Issue : Charging works fine as soon as I reprogram the bios ( Bios bin file is available on this forum ) . Then after few days ..like 4-7 days, ti again stops charging and battery shows as 100% always. If I unplug the AC adapter, the laptop shuts down immediately.
    Has anyone every has similar issue ?
    Thank you everyone for this wonderful forum.
  • anshad
    • Nov 2010
    • 249
    Re: Charging Issue comes back after few days ( Bios Reprogram Fixes it only Temporari
    Have you tried HP authentic battery on the machine ?. I have seen bizarre issues with cheap China brand battery packs. One of my friend has such an issue. The new compatible battery work for a few days and fails. He replace under warranty and the cycle repeats.Finally he gave up and bought an authentic battery and since then everything fine now.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Thanks for your input . The current battery is an Original HP battery. Unfortunately I do not have a spare battery for the same
      • piernov
        • Jan 2016
        • 4439
        • France
        Can confirm that there are a *lot* of garbage batteries on the market lately. Not uncommon to get 2 bad batteries (or even 3) in a row.
        I'd suspect the battery first.
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
        • elmark
          HP 15-cw1002ua strange keyboard issue
          by elmark
          HP Pavilion 15-CW1002UA
          S/N 5CD0251CBC
          P/N 7KE54EA
          Hello guys!
          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
          It powers on OK and has no other issues except the following:
          • CAPS LOCK does not work at all
          • Fn button toggles Flight Mode
          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
          • (with SHIFT pressed: 't%' and 'y^' respectively)
          I initially thought it was a keyboard malfunction (internal short, etc.),
          but when I press and hold...
          06-27-2025, 01:10 AM
