Samsung UN60FH6200F Backlights but no picture
  • doesntmind
    • Feb 2014
    • 61
    • usa
    Plugging TV in results in the backlights turning on without having to press power button.
    Pressing the power button causes the backlights to turn off for a second and then turn on again without anything displaying on screen.
    Holding the power button causes the tv to turn off and on in 1 second intervals.
    The readings from the connector that goes from power to main board while on are:
    Pin# - Desc - Voltage
    1 - B13V - 0V
    2 - PMW_DIM - 0V
    3 - B13V - 0V
    4 - B13V - 0V
    5 - VAMP - 0V
    6 - BLU_ON - 0V
    7 - VAMP - 0V
    8 - GND - 0V
    9 - GND - 0V
    10 - GND - 0V
    11 - B5V - 0V
    12 - A5V - 5.3V
    13 - B5V - 0V
    14 - PS_ON - 0V
    Disconnecting the main board from the power board results in the backlights turning on and off in 1 second intervals and voltage readings jumping up and down
    Disconnecting the main board AND the backlights result in the below readings:
    1 - B13V - 12.5V
    2 - PMW_DIM - 3.4V
    3 - B13V - 12.5V
    4 - B13V - 12.5V
    5 - VAMP - 12.5V
    6 - BLU_ON - 3V
    7 - VAMP - 12.5V
    8 - GND - 0V
    9 - GND - 0V
    10 - GND - 0V
    11 - B5V - 5.3V
    12 - A5V - 5.3V
    13 - B5V - 5.3V
    14 - PS_ON - 3.3V
    BACKLIGHT CONNECTOR:
    Pin# - Desc - Voltage - Colored wire to LEDS
    1 - D+ - 407V - BLUE
    2 - D+ - 407V - NC
    3 - NC - 0V - NC
    4 - S- - 0V - BLACK
    5 - NC - 0V - NC
    6 - S+ - 0V - BLUE
    7 - NC - 0V - NC
    8 - D- - 4.6V - NC
    9 - D- - 4.6V - BLACK
    What do you guys think?
    Pictures can be taken on request
    Power Board
    Model: L60G1_GHS
    or BN44-00669A
    Main Board
    Model: BN94-06418UPC07
    or BN97-06546E
    Thank you and please let me know if you need more information
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UN60FH6200F Backlights but no picture
    Hmmmmm....It would appear that you have LED backlights issue. The Main Bd and PSU seem to be OK. Do you know how to tear down the Panel to get to the LEDs?
    • doesntmind
      • Feb 2014
      • 61
      • usa
      Good Call! After reading your reply i went ahead and powered the tv with only the LED cable disconnected and now I get sound. I will post again after digging further into the unit to look for the cause.
        Yep, LED/WIRING/CONNECTOR issue that'S why the Voltage went up to 407V!
        http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
        • doesntmind
          • Feb 2014
          • 61
          • usa
          After getting to the LEDs i found 28 of them that went out. Thanks for your help guys, i know what to do from here!
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Change out all of the strips with new ones. The seemingly working old ones will fail in the very near future and you will have to do a repeat teardown and repair.
              MSI Pulse 15 B13V Notebook 15 Specification for Upgrade or Repair
              This specification for the MSI Pulse 15 B13V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 B13V boardview and 15 B13V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MSI Pulse 15...
              09-07-2024, 06:31 AM
            • max789
              Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
              by max789
              Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
              I made the following tests:
              1. Disconnected the main board from Power Board = backlight works.
              2. Connected the main board and disconnected the T-Con = backlights does not work.
              So I ordered a main board from Ebay also BN41-02156A but from...
              01-18-2024, 06:56 AM
            • fuxxy
              UN55D6000 - Multiple issues, now no standby light
              by fuxxy
              UN55D6000 I've posted about before.
              Initially had bad backlights, of which both entire strips were replaced.
              Then TV started not staying off. Every poweroff command was recognized, TV would power off then power right back on, even with nothing attached.
              Now, no output at all. No red Power LED, No response to remote. No clicking or coil whine.
              From other threads, tested various outputs on the PSU. Noticed that when the mainboard was unplugged, the backlights would turn on.
              Backlight Connector CNL802:
              Logic board unplugged:
              pin...
              12-23-2022, 08:49 PM
            • bpcannan
              VIZIO M557-G0: Backlights or ???
              by bpcannan
              'Morning,
              I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
              Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
              I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
              I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
              10-29-2023, 06:36 AM
