e470vl
  • apexlights
    • Sep 2015
    • 13
    e470vl
    I have a Vizio e470vl that is not accepting any input on the 3 HDMI ports.
    I figured this points to a bad chip.
    I have had no luck locating the service manual to do testing.
    Anyone have any ideas?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: e470vl
    Are they available to select in the menu?
    • apexlights
      • Sep 2015
      • 13
      Re: e470vl
      Yes they are
      • R_J
        • Jun 2012
        • 9588
        Re: e470vl
        Even if you find a service manual it likely won't help, The few I have do not have schematics and you would likely need a scope to trace the data lines. look at what ic is used for hdmi, find the pdf and go from there.
        • apexlights
          • Sep 2015
          • 13
          Re: e470vl
          find what pdf? for the ic?
          • R_J
            • Jun 2012
            • 9588
            Re: e470vl
            Yes, locate the hdmi ic, then try and find a data sheet for it, or post good clear pictures of both sides of the board, maybe it is similar to another brands main board.
            Also vizio is prone to eeprom problems so it could be corrupt data causing the issue
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Bugman1400
              Vizio E470VL got +5VSB, but no 12V
              by Bugman1400
              EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
              +5VSB= +5.09
              12V= +12.18
              PS_ON= +2.25
              I_ON/OFF= +3.27
              LAMP= +3.18
              DIM= +2.97
              Any more testing I can do on Main board or is it just a replacement?...
              09-04-2022, 09:19 AM
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • dholley
              Vizio TV E470VL SMPS Flucuation Output Voltage
              by dholley
              Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
              1. The 3 main filter caps all have approximately 167 volts steady
              2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
              3. I have replaced Fuse F102 with an equivalent
              4. I have check all diodes and caps and they seem to be ok
              5. I replaced the 431...
              01-20-2022, 03:12 PM
