Sharp LC-70LE650U 2 slow/5 fast blinks
  • Aggie2012
    • Jun 2018
    Howdy, I'm new to TV and tech repair but I'm pretty handy, I've been following a couple other related threads to try and solve a similar issue with a Sharp LC-70LE650U I found in the trash. It is giving me the 2/5 blinking error code. I followed the steps on the Tech TipsPDF that RJ posted on page 1 of this thread:
    https://www.badcaps.net/forum/showth...0LE732U&page=4
    I took off both ribbon cables from the TCon got the backlights to light up didn't see any physical damage to the panel. Reattached one ribbon (right side) and got half the screen to turn on, no cracks or damage visible meanwhile the blinking error code is NO longer happening. The tech tip sheet says if no physical damage is visible then there is a legitimate panel failure. I'm not sure what that means but I disconnected the right side and connected the left side and backlights don't come on at all and the blinking error code is back. Checked voltage from PD 1 at the main board to PL on the TCon board while both ribbon were disconnected and I got 12vdc at PL1&2 but 0 at 3&4. Checked voltage while left ribbon was connected (and error code blinking) and got 0vdc on PL3&4 and .03 on 1&2. Voltage check with right ribbon connected and left disconnected (no error code) and got 12vdc at PL1&2 and 0vdc at 3&4. And again with both disconnected (this time no error code) I get 12 at 1&2 and 0 at 3&4.
    So I guess my question is, is this a TCon issue or a panel issue? Or do I need to check something else? Any help y'all can offer would be great. Thanks,
    JW
    Texas
    Aggie2012 is online now Report Post
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp LC-70LE650U 2 slow/5 fast blinks
    it is likely that you have a "panel failure" with one or more of the side tabs that are bonded to the panel. The voltages you measure only tell part of the story, the resulting picture / display on the screen during your "testing" tells more. Anyways, there are plenty of threads on this type of issue where people are able to "save" the set by removing the tabs. Search and read as the "save" is a "one way operation" of removing the bad tabs on the side in question. After the operation is done, the set will be basically as "good and new".
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      On the side that shows the error there are side TABS that when removed can save the set but as budwich says this is a 'oneway' repair, they cannot be re-attached. This method has worked and has saved many sets from the junkpile.
      • Aggie2012
        • Jun 2018
        Thanks guys! I'll see what happens.
        • JayPoorJay
          sharp LC70EQ10U 2 slow, 2 fast blinks
          by JayPoorJay
          Good morning... I'm new here and have a LOT to learn.
          I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
          I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
          01-24-2022, 09:26 AM
        • joblo37pam
          Sharp LC-80LE844U Blinks 2 slow, 5 fast
          by joblo37pam
          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
          10-26-2023, 02:17 PM
        • Caimano
          hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
          by Caimano
          MB G7AD-2G DAG7ADMB8D0 REV D
          Processor i5 8265U
          AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
          Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
          Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
          02-06-2024, 10:14 AM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • zesko
          xps 9520 ribbon cable
          by zesko
          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
          There is 2 models, idk which one is needed on my laptop.
          0xkvng
          00vpr2
          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
          thanks...
          10-23-2025, 05:03 PM
