Panasonic TC-P50S2 7 blinks
  • jason123
    • Oct 2015
    • 1083
    Re: Panasonic TC-P50S2 7 blinks
    Ok, replaced the resistor. I get a green light on the SC board (SU / SD disconnected and Jumper shorted)..
    Then I get 6 blinks. Upon testing the SC card, I don't see anything failed, but now the SS card is pretty much shorted. Almost all the FETs / Diodes are shorted. What am I doing wrong??
    • NYKing
      • 17
      was the driver boards repaired or tested before connection to SC board?
      • jason123
        • Oct 2015
        • 1083
        Yes, the SS board FETs and Diodes where spot checked before the repair. After the SC repair, that's not the case. Thanks
        • jason123
          • Oct 2015
          • 1083
          Ok I am about ready to take this TV to the backyard and practice some shooting!
          Green light on the SC (repaired), new (used) SS card with green LED on. TV turns on, momentarily I see a sign of life on the screen, then shuts off with 6 blinks. SU SD don't seem to have any shorts. What am I missing, expert friends???
          • jason123
            • Oct 2015
            • 1083
            Ok, I decided to replace the SC card with a working one, and voila, the TV is working again.
            I still don't know what I missed on the SC repair with ShopJimmy kit.
            • budwich
              • Jul 2015
              • 3097
              glad you got it working. there are lots possible control circuit smd's (ic's) on that board that could be bad / marginal. Not sure which or how many you replaced. I am hoping that I don't run up against the same issues when I finally get around to attacking my 50s30 set (still waiting on parts).
              • N9ZN
                • Jul 2018
                • 3
                I am going to wish you good fortune with your 50s30 set. As for myself I am in the middle of troubleshooting and repairing the P, SS, and SN boards on my TC-P42ST30 set. It seems every time I think I am close I jump into another area and find diodes shorted and other things but I am going to wait until I have the first round of suspected bad SMD's replaced. What I am hoping I am seeing are a false reading due to components being in proximity or in circuit with known failed shorted components. I am posting because the two sets are similar and I want to follow this thread.
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
                • CrewmanRedShirt
                  Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                  by CrewmanRedShirt
                  Hello all,
                  As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                  07-13-2024, 11:02 AM
                • nobbnobb1
                  Panasonic TC-P50U50 Powers Off - 8 blinks
                  by nobbnobb1
                  I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                  2x DG302 (Q16051)
                  2x RF2001 (D16041)
                  2x 5.6 ohm SMD resistor
                  1x BD8694 IC
                  I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                  03-21-2023, 08:33 PM
