Panasonic PT-51G41V PTV Poor Convergence Weak Picture
I've fallen into another dank hole I'm afraid.
History - He is the original owner. He had someone else work on the set several years ago for a "colors too intense" issue. Some transistor or other component was replaced and problem was solved.
Present problems - Owner indicated that set was working fine one day and then bad the next. This was about 2 years ago. Unit was subsequently moved to their new home. The unit seemed to be having convergence issues. Attempts by the customer thru the owners menu to adjust convergence were unsuccessful.
My inspection revealed a blown 33uF 160 volt cap on the TNPA0609 "D Board". It filters the 140 volts being fed to the Horiz drive and ABL circuits on this board. I replaced the cap and the convergence issue seems to have cleared.
However, the picture is at best "weak". Since the customer said it was okay one day and then bad the next, with the convergence issue, I don't believe it's the tubes. Any ideas where I should be looking for the problem?
There is a whole series of steps to take in "Serviceman Mode", but I can not (will not) perform them in the customer's home. I need the set brought to the shop where I have the equipment and the ability to concentrate on it.
Do you think it is worth the effort, or should it be parked on the curb? Is there a list of "common" problems in these sets I should go searching for?
Opinions and recommendations greatly appreciated.
Toast
Toast
to look at tubes. They're bright, but not as bright as I remember when looking at others. Those really hurt to look at
